identity tv part
  • nosugartonight
    replied
    Re: identity tv part
    Here is a pic
  • nosugartonight
    started a topic identity tv part
    identity tv part
    ON a power board. This part looks like a resistor but has no color bands. It is marked jw2 4.7 with ohms sign. They are 3 in a row. Checking in diode mode they read closed. What are they and what should they read.
  • edugimeno
    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
    by edugimeno
    Hi There!
    I'm trying to help my friend who owns a restaurant be just bought.
    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
    It's stuck using, I guess, the 2 sided tape that comes with the strip
    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
    09-05-2024, 09:34 AM
  • G-Sting
    iPad Pro A1876 SHORT Part Identify Help Needed
    by G-Sting
    So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
    So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
    i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
    SO My main concern is what part should i order what should i search the name for ?
    on Ipad...
    05-15-2025, 09:30 AM
  • narf
    Epson EB-U42 projector / Caps with 0.7 ohms ?!
    by narf
    hi all,
    first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
    i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
    what i've found so far:
    - the PSU does its job and supplies 12V to the mainboard via the connector.
    - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
    - not far away, there's the first cap with a resistance of 0.7 ohms....
    07-02-2024, 03:53 PM
  • Yanleb
    Panasonic part number in service manuals
    by Yanleb
    In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
    This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
    For an example, look at the attached PDF.
    Do you have a way to cross reference the Panasonic part number with the actual part number?
    Thanks....
    07-03-2023, 08:16 PM
  • FreakyMex
    Trouble to identify part (Lunii screen) for replacement
    by FreakyMex
    Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
    I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
    02-17-2025, 01:16 AM
