47" Vizio - slow to turn on and switch sources
  • jayjr1105
    • 281
    DOM appears to be early 2010. CFL backlit I believe not LED (E472V is the model I believe)
    Cracker her open but don't see any obvious signs of trouble. From my research, KY caps are good stuff. Any other things I should be checking?
    It runs fine but I noticed it takes twice maybe three times as long to power up as it used to. Also, switching from one HDMI to another or HDMI to tuner takes longer.
    https://imgur.com/a/18is0
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-06-2024, 05:30 AM
  • ajc333
    Dell Precision 7710 - it can not be turn on and off with the switch
    by ajc333
    Hello.
    Markings on the board AAPB0 LA-C551P REV:4.0 (A03). The laptop came to the service with the fault of shutting down after a few minutes of load such as a game. It turned out that the smaller fan was damaged, a complete original cooling system from dell was ordered and from this time everything is back to normal. The problem, however, is the inability to turn on and off the laptop with the switch. On the switch board, the voltage drops from 3V to 0V when the switch is pressed.
    On the connector on the board (from the right side) I have the following voltages:
    n1. - 3V after...
    03-10-2023, 07:27 AM
  • Mulp
    VIZIO M65-C1 Does Not Turn On
    by Mulp
    Hi All,
    I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
    When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
    I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
    01-13-2024, 09:57 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Natob82
    Micro Momentary Push Switch?
    by Natob82
    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
    12-21-2022, 05:22 AM
