I made the unfortunate mistake of buying a couple of TV's that had these crappy vestel parts inside. I tried to fix this one and gave up, but now another TV with the same board has also blown so i bought a new board for that. I thought it would be sensible to compare the new and old blown board to see if it helps me figure out whats wrong, but so far i'm struggling.
The board is a 17PW06-2, the schematic i am using is:
When the board initially died, it only appeared to have one shorted output diode. I replaced the diode and the TV ran for about 2 minutes before making an almightly bang and leaving a skidmark on the TV chassis
A good inspection found that all of the current sense resistors (R301+R304 in my case) were exploded. The PWM controller ICE3BR1765J was burned on it's CS/Current Sense leg and tested short. Nothing else appeared to be burned or test shorted that i could see.
I replaced all of the output diodes, the PWM IC and the CS resistors with 2R2's. Oh and naturally the fuse was popped as well, so i changed that.
I took the precaution of powering up the board in the TV with a light bulb. The lightbulb stayed off thankfully, but i noticed that the red led on the set just kept flashing. The transformer(s) also kept ticking in time with the flashing led. My only understanding of this symptom from past experience has been from short circuits making the set shutdown and restart. I powered up the TV again without the lightbulb incase it was the bulb stopping the TV entering standby, but it still kept flashing and ticking.
I've been slowly comparing the new board i purchased with this one, making resistance comparisons and diode mode comparisons. I haven't come across anything that is way off. All the caps have been tested with an ESR meter and the values match up.
After studying the schematic some more i got the datasheet for the IC301 PWM controller and tested it's pins while turned on. I've found that the CS pin jumps about and hits up to 9v in DC mode. Apparently the max threshold is about 1v before the chip turns itself off and restarts? So it would seem there is still an over current situation, which originally killed the board in the first place.
I really don't know where to go from here, any ideas i can try?
P.S. one thing is niggling me and that is the output diodes of TR300. The original diodes were SR5100, but when i purchased replacements i was told that SB5100 is an equivalent. However, when i test the diodes in diode mode, i get a drop of .200 with the SR's and .300 with the SB's. Would this difference cause any problems?
Help, much appreciated.
James.
James.
