LG 47LN5200 and similar models common fail + easy fix
  • triplefour
    • May 2014
    • 1747
    just thought i'd share my experience as i came into a few LG sets that shared this same panel and they all failed the same way. the PSU could be tricked on, and was giving enough volts that should have powered the LED strips, but i wasnt even getting so much as a flash.
    after taking apart the panel and finding a bad LED (or two) i reassembled the panel only to see it doing exactly the same thing. according to my LED tester, all the strips were fine now, and according to my voltmeter, the PSU was outputting good voltage but still nothing.
    i took apart the panel again to see if volts were actually going to the strips and discovered they werent.
    so what it turned out to be was the LED connector on the PSU even though it looks fine and like its making enough contact, it just isnt. i dont know how this can go bad over time (maybe oxidized?) but it's a loose fit to begin with.
    i took some super thin copper strands and fed them through each pin hole of the connector and around the back and just kinda twist tied them in place (to add more copper material inside the pin holes) and jammed that sucker back in there and now it works flawlessly.
    i literally did this same fix to 3 LG's in a row, so i guess this is a common failure where the connector stops making good contact (maybe leading to destroying some LED's?)
    anyway just thought id leave this here in case anyone comes looking for info about LG 47LN sets...
    Don't fear the repair...
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    Replaced emmc.
    Terminal log
    UART
    AC_ON
    E-B
    FDE enabled
    06-01-2025, 02:11 AM
  • EvazX
    ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
    by EvazX
    I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
    Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
    For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
    However, after some time, the replacement motherboard...
    08-25-2025, 06:09 PM
  • NotEnough
    Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
    by NotEnough
    I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
    What I've Tried So Far:
    • Reseated the cables.
    • Reinstalled AWCC and AlienFX services.
    • Attempted BIOS downgrade but no improvement.
    • Inspected ribbon cables for damage.
    • Explored the possibility of BIOS or
    10-19-2024, 01:34 AM
  • psssst
    Yamaha TSX 120 Standby Problem
    by psssst
    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
    03-01-2024, 07:25 AM
  • J_T
    Operating frequency for motherboard common mode inductor/filter
    by J_T
    I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
    The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
    Sorry, I am not experienced hence a basic question.
    01-04-2025, 05:54 AM
