EBR73712701 YSUS No Vsc
    Re: EBR73712701 YSUS No Vsc
    Nah I think I probably killed it messing with the Ysus. All the ribbons look clean.
    Going to pull the scan ic tomorrow to get a part number.
      OK cool. Just to confirm everything else is cool with your Ysus Usually I heat up the IC in carefully remove it until I measure no shorts then you can plug sustain board back in as long is there are no pins touching each other and power it up. You're going to have a black spot where the IC is reemoved however you should have your data drive back and you should have the relatively good looking picture minus the area that you removed.
        That's exactly what I'm going to do - thanks for the feedback.
        And btw, not a single broken, "for parts" buffer on ebay to snag a scan ic from. wtf ?
          The scan ICs are pretty universal parts, in a lot of cases you can use the same scan IC used in a previous generation if it's got the same number of pins.
            I don't think I have any buffer boards around here. I have a few Samsung scan ic's but they're from a 720p set. Probably just buy a used but working board.
              720p and 1080p buffer ICs are often similar,
              1080p sets have 12 sets of 96 channel ICs for >1080 lines (some are unused)
              720p sets have 8 sets of 96 channel ICs for 768 lines
                Ya I went looking for the ic's I have and came up empty...
                But I did remove the shorted ic cleanly and made sure there was no pin bridging and reinstalled it. The result is ambiguous. Same missing voltages and no prime/ no pic. I removed it and ran it again with only lower buffer and got the expected prime and garbage on the lower half presumably where osd is.
                Not sure if that result is merely a peculiarity of this set. At least I hope so.
                  Found a single FE3407F same package and looks to be the same electrically. The legs are all jimmied up though. Will probably pop right away but will attempt to straighten the legs and get it installed. Fun fun fun.
                    You should be able to run that TV with the shorted ICs removed. Unless there are other shorted ICs on that top buffer board as well.
                      I don't believe there are any more shorts. Will check again though.
                        As long as the ysus is ok. I'm on the verge of ordering a replacement board anyhow.
                          Is there any convention to locating Pin 1 on an ic with respect to the writing on it ? This FE3407F scan ic I have has no visible marking and web info is scant.
                          I believe it to be the bottom left when reading the chip info but of that I am not certain.
                            Well that was fruitless. Absolutely no change. I have to wonder if there's still something wrong with the ysus. But why does having only the lower buffer connected produce a pic ?
                            If the problem is indeed the upper buffer board then I'm a little concerned that it's quite possible to buy a dud replacement without it showing signs of a short yet still not working.
                              I suppose. Anything is possible. Also have you considered a short in the panel I know it's far fetched however my assumption is would be alleviated if you were to try to run the buffer without the panel connected to the buffer. I've done this before however only on Samsung's I'm not sure what the outcome would be on LG
                                Worth a try before I spend money on a buffer I think
                                  Ran the set with the buffers installed but the upper buffer panel ribbons NOT plugged in. Same result - no raster and no Vsc/-Vy.
                                  When I run with the lower buffer only I have good -Vy and garbage on the screen but no Vsc because the upper buffer is not installed.
                                  So,
                                  either I have something on the buffer failing under load.
                                  Or,
                                  something failing on the Ysus when Vsc attempts to come up.
                                  Will sleep on it.
                                    Huh odd. Imho If you see anything on the screen you have to have Vscan coming out of that board. Can you post a picture of what you're seeing on the bottom half of the screen?
                                      I'm sure that's a No Signal or such box floating around. I've since read a few accounts where very similar or same symptoms were solved with a new upper buffer so I'm going all in.
                                        Looks like a new upper buffer will solve your issue. Thasts a normal picture when data even and odd signals are not reaching buffer.
                                          Update: after some misadventure with USPS and receipt of a "working" (shorted!) upper buffer I finally took possession of working upper and lower buffer set.
                                          I think messing with the set led me to kill a probable good upper and definitely good lower. It's possible I could have got away with touching up the joints under the transformer. Ah well, working now...
                                          Thanks for the help.
