EBR73712701 YSUS No Vsc
    Re: EBR73712701 YSUS No Vsc
    -Vsc = VFG, the Y-sustain board output
    +Vsc = the VFG+VSC going to Y-sustain
    Vsc is passed along the buffer boards, so the Y-main just connects the two together
    The source is around the 10 ohm resistor and diode pair which form the impulse reduction network (Prevents buffer IC destruction due to sudden picture load change.)
    • mmartell
      • Oct 2013
      • 3189
      This is what I'm getting at - without an upper buffer connected there's no way to read a working Vsc at the test points. So since I have 150v at the resistor you're talking about I have a problem in my buffers or panel.
      Correct ?
      • freakaftr8
        • Oct 2012
        • 3743
        You need to have at least one buffer connected upper or lower to properly load VSCAN. However with not having the top buffer installed only the lower buffer installed your picture will not be proper due to data drive signals not being carried from the upper to the lower. But you should still have VSCAN no matter what.
        I mentioned only trying the lower buffer because like I said before this particular series of plasma TV's have a problem with the plastic frame rubbing into the top buffer output to the panel causing a short loading down VSCAN.
        What I have found in my previous years of working on plasma, the VSCAN will operate with or without buffers installed. Sometimes you'll have a floating VSCAN voltage due to the fact that it's not loaded down but it should still be there
        • freakaftr8
          • Oct 2012
          • 3743
          This is your VSCAN test points? Red to +, Black to -.. do you have voltage there?
          • mmartell
            • Oct 2013
            • 3189
            No I do not but that is exactly my point. If you look at the solder side of the board it looks like Vsc+ never makes it to the test point except when it is passed through the upper buffer.
            I've also read about the ribbon being damaged, I did a quick inspection on the second from the top ribbon and I see nothing.
            Testing with the bottom buffer properly... disconnect upper buffer from the Ysus and leave the data ribbon connecting the two buffers connected ? Or remove upper buffer completely ?
              On this particular set it appears that Vsc is passed between the buffer boards by the Y-sustain. So indeed with a missing upper buffer you will not read Vsc. This is NOT the case for every plasma. They do things differently on different sets.
              You need, in this case, to check Vsc with all boards in. If the voltage on the big 10R resistor is LOW after this, you may have a shorted buffer
              • mmartell
                • Oct 2013
                • 3189
                Ok guys much thanks for the input will report back with the results.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  O yeah I just looked at the bottom side the board lol you guys are absolutely spot on. What a cheaply designed passive system. I remember LG built TVs that were robust without making cheap single layer boards that crack from heat.
                  It's been a few years since I looked at my PA 5500. That was operating without a top IC because of the ribbon short in my shop running news 8hrs a day.
                  This particular series shorts the IC if it has one or more missing output lines.
                  Make sure to check that very top IC on the upper buffer board for shorts. I noticed you mentioned 2nd from the top ribbon for rubbing it is not it is the very top ribbon you want to look at closely.
                  • mmartell
                    • Oct 2013
                    • 3189
                    D'oh! I read somewhere it was second from the top will have a look. Is the failure mode to have intermittent video ? That's what was reported by the previous owner and that's what I saw when I first turned it on at home. Since then, no video. That would be an incredible coincidence for it to fail in my possession and right away at that.
                    Are you saying running the set with only one buffer will short it out ?
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      I suppose it's always possible considering on the movement and transport of the tv could have caused it to you get worse
                      • mmartell
                        • Oct 2013
                        • 3189
                        Ok so reassembled and no prime and no Vsc and no -Vy. Well there is a slight buzz from the ysus about every second and the -Vy goes from about 13v to around 30v. Vsc is essentially zero.
                        Either the ysus is not repaired properly or I have a failed buffer dragging down my ysus.
                        Is it safe do you think to run the set with just the lower buffer to see if I get prime and good voltages ?
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          I suppose you could always try it wouldn't hurt.
                          • mmartell
                            • Oct 2013
                            • 3189
                            The buzzing about once per second is coming from the Vy/Vsc transformer. Probably normal against whatever is causing the voltages not to come up.
                            I looked at the upper panel ribbon - looks ok too.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              You had -vy before. Was this with buffers disconnected or connected because if you tested it disconnected before then buffers are loading down the y board since connected no -vy
                              • mmartell
                                • Oct 2013
                                • 3189
                                Correct. I have both of those voltages without buffers connected. When connected they are gone or pulsing at a much lower voltage.
                                I've forgotten how to bench test buffers properly. Will look it up to verify a short in one or both.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Most likely a buffer short. Most likely vscan does not come up without buffers connected and connected dead short considering the pulsing ysus. In this case you will not have vscan either way.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    I believe in diode check mode black lead to any of the aarows on the input connectors, red lead run it down the outputs with the clips up. Look at the readings. Maybe a beep on even one line output.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Confirmed upper buff short in either the top one or top two ic's. I've replaced these scan ic's on Samsung buffers anyone have the same success on these LG buffers ?
                                      By the way there is some artifacting going on with only the lower buffer installed. Nothing you can make out but big blocks of things probably where the on screen display is.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        That's normal with no top buffer installed. Data doesnt drive to lower without upper installed. Now that you mention top buffer IC short I would really scrutinize those ribbon cables going into the panel. Hopefully you're lucky and it's just a shorted IC, However this is how this model represent itself when there is a problem with the ribbon cable. Look for any micro fractures or cracks from the plastic bezel rubbing into the ribbon before replacing buffer board.
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          And yes you can replace a bad IC. Same as Samsung if you've done it before. 1080p is more of a pain in the ass since there's more pins then 720p I've learned.
