EBR73712701 YSUS No Vsc
  • mmartell
    • Oct 2013
    • 3189
    From an LG 60PA6500...
    The PO stated the set would lose video soon after turning on and after leaving it unplugged for some time the video would come back and the process would repeat.
    This was verified by me. After taking measurements I found that -Vy and Vsc were missing - all other voltages present and on spec.
    After touching up some dry joints on the transformers -Vy has returned to -185v and appears to be stable. Still no 150v Vsc. Obviously it was present at least temporarily for me to see video but now I can't get it back.
    All voltages were measured with the buffers disconnected, though I've run the buffer test and they appear fine but I think it best for the time being to remove them from the equation.
    I have 149v at both sides of the 10 ohm power resistor at the top left of the board which I think my be the Vsc but it doesn't make it to the test point. Having a hard time tracing the circuit.
    Any help appreciated.
  • mmartell
    • Oct 2013
    • 3189
    Re: EBR73712701 YSUS No Vsc
    Some pics...
    • mmartell
      • Oct 2013
      • 3189
      Better pics courtesy of SJ
      • mmartell
        • Oct 2013
        • 3189
        Anyone have any insight on this ?
          Both -Vy and Vsc are generated by the same transformer. If -Vy is good then Vsc should be too, so it must be a cold joint or a blown fuse somewhere, or something like that
          • freakaftr8
            • Oct 2012
            • 3743
            Attach lower buffer only. Check vscan.
            • mmartell
              • Oct 2013
              • 3189
              I've read that but I have no vscan with NO buffers connected. Does Vscan need a load on it to come up ??
              • mmartell
                • Oct 2013
                • 3189
                So the smaller transformer is for generating the 18v for the X sustain then I take it.
                I think the joints are good now. It's difficult for me to trace the circuit but that information might help me trace it back some.
                • mmartell
                  • Oct 2013
                  • 3189
                  Hey tom how would I check the output of the transformer, I mean since it's floating where would I put my negative lead ?
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    That was my thought. This model and it's 50 inch brother are known for plastic frame ribbing the panel y ribbons shorting a top buffer IC and killing vscan.
                    You could try chassis ground for lead negative, but on the buffer ther e should be a test point for vscan + and -
                    • mmartell
                      • Oct 2013
                      • 3189
                      There's a test point on the ysus behind one of the connectors but the voltage never reaches there. I can try using one of the test points for the negative lead. Trying to find out if the voltage is coming out of the transformer or where it stops.
                      • R_J
                        • Jun 2012
                        • 9551
                        It looks like vsc uses chassis for ground, the + connects to both upper & lower buffers at P155 & p153. You will need to trace that point on the buffers to see where it comes from. tell us which plug and pin, then trace it back on the ysus
                        You can see where the vsc adjustment is, so that is part of the vsc circuit
                        I will guess based on where the VSC adjustment is, that this could be the path???
                        • mmartell
                          • Oct 2013
                          • 3189
                          Where you're line ends is the last place I see the voltage. It gets lost between there and the test points behind connector P153. Basically in the area behind connectors P154, P155 and P156.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Looking at the solder side I'm not entirely sure how one could read Vsc without having the buffers installed. The circuit seems to complete through the upper buffer board and then continue through the lower. I must be wrong.
                            Also chassis ground is not continuous with the negative test point. You can see where the negative test point connects to chassis ground through some poly caps between connectors P153 and P155.
                            • tw2005
                              • Oct 2011
                              • 6458
                              Could there be a chance a winding could be open cct in that large transformer?
                              I've had several in the series prior both 50 and 60 inch as they use the same transformer have defective windings which go open.
                                Remember that the entire output of a Y-sustain board is based on a floating ground. The sustain output which swings 200V-0V and ramps to -190V has Vsc added to it for the Vsch output, or the buffer positive. All the buffer ICs do is select between the Y-sustain output and Y-sustain+Vsc, the higher voltage acts as a select for writing individual lines on the panel.
                                So when you are tracing Vsc remember it is not relative to the chassis but in fact it is relative to the Ysus FG (floating ground) output
                                  Smaller transformer generates the F18V, which floats above the FG, think that's used to generate FG5V (for Y-buffers) and FG15V (for gate drivers on Y-sustain)
                                  • R_J
                                    • Jun 2012
                                    • 9551
                                    I was wrong about the (-) for the VSC, Its hard to tell what is ground and what is not just going by pictures,
                                    I see a small pico fuse near the 10 ohm/5w resistor, or is that a small cap?
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Will check that shortly...
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        It's a pico fuse - I have 110v on either side of it with respect to Vsc- test point.
                                        I'm still stumped by the fact I see no path for Vsc from the upper buffer top connector to the Vsc+ test point
                                        Do the buffers need to plugged in to get Vsc ? If so then I would guess I have a failed upper buffer.
                                        • bman4
                                          Lg 60pa6500 149v va
                                          by bman4
                                          Got this plasma to fix and was told black screen.
                                          The tv was working for me for a month after sitting unplugged for a year.
                                          Then i was getting black screen with sound and button funtioning .
                                          After i leave it unplugged it worked but now its worse.
                                          No bad solder joints.
                                          The logic board xd chip burns to the touch.
                                          The logic board has a later date then the others and read about the reprogramming because out of sync .
                                          I tried heating the logic board and dont know of it acclerated the turn off period.
                                          12-15-2021, 02:31 PM
                                        • valente222
                                          HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
                                          by valente222
                                          I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
                                          there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
                                          n, please identify.
                                          330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
                                          SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
                                          I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
                                          06-27-2024, 06:11 PM
                                        • air_chair256
                                          Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
                                          by air_chair256
                                          I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
                                          Tried to reball RAM 1,2,3,4
                                          Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
                                          02-13-2024, 06:00 AM
                                        • javieromex
                                          Dell G15 5511 LA-K452P won't turn on
                                          by javieromex
                                          Hello, any help will be apprecited!
                                          • Model: Dell G15 5511
                                          • MB: LA-K452P
                                          • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                                          • Customer reported it was turned off and left plugged in during the night and thats it...
                                          • No signs of liquid damage or burned components.
                                          Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                                          I have checked so far:
                                          04-17-2025, 12:44 PM
                                        • Prott
                                          Surface Pro 7 - SLP_S4 present, then gone
                                          by Prott
                                          Hello fellow Badcappers,
                                          I have a problem with stubborn Surface Pro 7. I narowed it down to disappearing SLP_S4# (gone after around 200 ms).
                                          Everything else works as it should (the whole power on sequence succesfully finishes, all the voltages are present) until this signal goes missing - with it missing the AND gate causes ALL_SYS_PWRGD to go back low and this makes VCCIN drop to 0 V as well. Interestingly the SLP_S4_DRV# signal from SAM is still present for a second, even after SLP_S4 is no longer there. I wonder what could either cause PCH to stop sending the signal or what...
                                          12-03-2023, 06:11 PM
