samsung lE22B450C8W no standby
  • Bing
    • Nov 2017
    • 17
    • United Kingdom
    hi, i have a Samsung 22" lcd tv which has no standby voltage, i done a bit of investigation and found a shorted diode on the standby circuit, my question is should i just replace the faulty diode or is there other components i should also check? with limited knowledge would i be right in saying these diodes would be running at high frequency which could make them very hot as to fail?i think they are rectifying the output from the standby circuit transformer?
    Also to source a replacement do i only need the top number printed on it being SB560? i will post some pictures below thanks for reading!
  • Bing
    • Nov 2017
    • 17
    • United Kingdom
    Re: samsung lE22B450C8W no standby
    Here are pictures of power supply board.
    • Bing
      • Nov 2017
      • 17
      • United Kingdom
      Please note D105 and D106 I have removed to check D105 being diode which is showing short.
        This is an always on power supply, there is no standby, the power supply is always running at soon as the AC is applied to the board.
        It has 5V and 14V outputs.
        D105/106 didoes are connected in parallel to produce the 5V supply, the other 3 diodes are connected in parallel to produce the 14V supply.
        SB560 is the number: https://cdn.badcaps-static.com/pdfs/...3cbdc28824.pdf
        • Bing
          • Nov 2017
          • 17
          • United Kingdom
          Thanks for the info, just out of curiosity and if replacing the diodes does not fully resolve issue, if the transformer t101 is powering the 5 volt supply, what is powering the 14 volts supply? please excuse my lack of knowledge as only a novice! Thanks for reading
            Same power transformer is used for producing the 5V and the 14V, It has two secondary windings to make those two Voltages.
            You can run the power supply board by itself without any other boards connected.
              09-07-2024, 05:50 AM
            • ChristianBr01
              LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
              by ChristianBr01
              I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
              The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
              What I already found is that the 12.8V are not an the connector to the main board connector to the power...
              04-23-2025, 01:48 AM
            • Kaar3l
              Samsung QLED QE65Q7FNAT only standby light
              by Kaar3l
              TV: Samsung QLED QE65Q7FNAT
              PSU: BN4400940A
              MB: BN94-12832K
              I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
              09-24-2024, 01:35 PM
              09-06-2024, 11:40 PM
