Sharp Aquos LC-37D62U - Shuts Off
  • THRobinson
    • May 2017
    • 13
    I have a Sharp Aquos LC-37D62U that I got used (free) because it randomly shuts off. Could be 20min, hours or even go all day no issue, just randomly shuts off for about 5sec and turns itself back on again.
    Seems to be a VERY common issue with these older Aquos TV's, found lots of info about the issues, except mine seems to be a bit different.
    From what I've read, the power LED light should blink a code
    1x per second (constant, steady blink) = bad inverter/lamps
    2x per second = bad power supply
    3x per second = bad main board
    But, mine doesn't blink... stays solid green when shuts off, and doesn't blink anything.
    Any ideas?
    I suspect a heat issue... seems OK if a fan aimed at it at the back. Haven't used since summer though, didn't have the time to work on it. Looking to get it working again though because my niece got her own place and needs a TV.
    Could this be a cap issue? Saw a video on something similar, replacing all the 1000uf caps (x4) but different model.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sharp Aquos LC-37D62U - Shuts Off
    Sounds like maybe bad connection. Poke around with something non conductive, flex cables and see if it shuts down
    • claytongarcia
      Issue with Sharp LC-42SB45U
      by claytongarcia
      I recently got a model Sharp TV, and I've noticed that the green power LED is flashing without any specific pattern. Additionally, there appears to be no voltage coming from the power board. I haven't observed any leaking or bulging capacitors, although the top of the larger capacitor doesn't seem to be perfectly flush with the jacket—if that makes sense.
      Has anyone dealt with this issue before?​
      03-10-2025, 07:27 PM
    • sefoster
      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
      by sefoster
      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
      11-20-2022, 09:29 AM
    • scubacamper
      Sharp Aquos LC-70C6400U Half Screen Dark
      by scubacamper
      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
      05-03-2025, 12:19 PM
    • leorivers
      Issue with Sharp LC-47SB57UT
      by leorivers
      I bought Sharp LC-47SB57UT 6 years ago. I had to have a vhf antenna to pick up one local station(koco channel 5 OKC). It has worked great up until a week ago. Sometimes I couldn't get channel 5, now I can't receive it at all. I can hook up a digital convertor box I have from another tv and can receive channel 5.
      I think the antenna and cable is ok. I doubt that this would be the tuner board or possibly something else.
      Any ideas where I should start?​
      10-24-2024, 03:11 AM
    • klassic
      Sharp Aquos LC-60LE635E three blinks
      by klassic
      Hi community,
      I will describe my problem with a TV in those short following terms to be the most precise :
      What i have :
      power board DPS-162KP-1
      main logic board QPWBXF733WJN2
      symptoms :
      white led light logo at startup,
      after 2 minutes, blinking 3 times a row, repeating
      no backlight (and apparently no picture, checked panel with flashlight)
      no startup sound
      powerboard investigations :
      1-2 PNL : 0v
      3-4 GND
      5-6-7-8 UR : 13.15v
      9-10-11-12...
      10-24-2023, 01:39 PM
