50pk540
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    50pk540
    I repaired a LG 50" plasma 50pk540 with an intermittent shutdown. Turned out to be cracked solder joint on a transformer on the power supply. I touched up all the major solder joints on the x and y mains while I had it apart. I pluged it in and it fires right up and never shut down( ran for 9hrs). I put the stand on it and pressed the menu button and saw 2 one pixle wide lines about 1" apart, just left of the center of the set. I tried to clean and reset the ribbon on the control board and the one that goes to the screen from the XC center buffer. No luck. I then disconnected. That ribbon again and turned it on and of course that segmet was off, but looked like a maldischarge, and I could still see faint lines. Maybe it is screen burn in, in reverse???? Gonna try a 10 dollar XC buffer. Oh, the lines dont show up on full white screen and they show on most of the test patterens. I will keep you posted.........
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: 50pk540
    Bad panel.
    • tw2005
      • Oct 2011
      • 6458
      Re: 50pk540
      Originally posted by tvtimmy
      Bad panel.
      yeah, had that experience twice now my self including that was perfect and was selling and whenever I get an enquiry I always like to fire it up and confirm it's good.
      Blow me, a line appeared , all that hard work .
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Re: 50pk540
        Today I got a 50Pk750 with a bad mainboard for free. It has the same panel as the 50pk540 I have with the bad panel. I swapped the mainboard, ldvs cable(to short), and the ir cable. The tv works just fine. Only thing left to do is clamp both tv backs together and drill new screw holes, as only 4 match up now.
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • zesko
          xps 9520 ribbon cable
          by zesko
          I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
          There is 2 models, idk which one is needed on my laptop.
          0xkvng
          00vpr2
          Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
          Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
          thanks...
          10-23-2025, 05:03 PM
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
