Samsung Plasma advice please.
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    Hi I have two Samsung Plasmas with cracked screens.
    A PS43D450 and a PS42C450. Although the model numbers are similar the TV boards are quiet different.
    Anyway I have been searching patiently for a year or more for faulty TVs with good screens, so that I can swap some parts, but having no luck at all.
    The PS43D450 powers up, nothing on screen, no Samsung chime. TCon flashes on for about 4 sec off for 2. Test voltages rise and then fall.
    The PS42C450 powers up, screen flickers, good Samsung chime. TCon flashes on for about 4 sec off for 2. Test voltages rise and then fall.
    How confident can I be that the boards are good and that I can sell them? I just want them gone at this stage.
    Re: Samsung Plasma advice please.
    Either may have bad buffer boards.
    You can test using this video:
    https://www.youtube.com/watch?v=51SZsfH60EY
    The other boards are probably ok, but it is hard to tell without an oscilloscope.
    • habanerocat
      • Nov 2014
      • 96
      • Ireland
      Thanks. I have an oscilloscope.
      If you could point me in the direction of another guide, that would be great.
        Is your scope a digital scope that can pause the waveform?
        If you post a picture of your Y-main I will show you where to probe.
        You need to be able to pause the waveform because there's a good chance the set will detect a fault due to the cracked panel and shut down. So you'll only get a few cycles of a waveform before it dies.
          09-07-2024, 05:50 AM
        • Cooperr
          Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
          by Cooperr
          I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
          The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
          10-21-2025, 01:11 PM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
