samsung ln46a650 BN44-00203A psu part identification
  • veikra
    • Sep 2012
    • 55
    • canada
    I need help identifying these parts
    The green resistor sit with one leg on either side of the relay power terminal. It blew up from a short circuit or current overload upstream.
    The black inductors (deducted from symbol on board) I think they are the reasons for blowing fuses. These produce a .2ohm short between - and + of the big line capacitor if they are in circuit.
    Might be a rabbit hole though! Need the green resistor to test
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: samsung ln46a650 BN44-00203A psu part identification
    The green thing is a thermistor? The black things look like ferite beads to me. Somebody smarter will chime in with answers.
      NTC, 5 Ohms cold resistance.
      What is the diameter of that NTC?
      The Ferrite bead is find, I would look for shorted semiconductors.
      • veikra
        • Sep 2012
        • 55
        • canada
        NTC is 13 mm of diameter.
        The ferrites causes a short between + and - of the big 450V capacitors, so I know the problem is probably over that side of the circuit which they feed
        Downloaded the pdf, going through it
        • veikra
          • Sep 2012
          • 55
          • canada
          Q816 was the short I was looking for. Diagram made is easy
          • veikra
            • Sep 2012
            • 55
            • canada
            q816 and the ntc resurrected all low voltage. Tv runs but no backlight. Flashlight conclusive. Power on main 450V caps is low.
            QI814 RI868 and ZDI805 blew up. What could cause this? They all sit around Q816. I dont think I missed seeing those when cleaning the board, but it is a possibility they already were.
              Qi815 is connected in series with QI816, so for you to get shorts reading after the BI801/802 then QI815 has to have low resistance between S and D pin also.
              QI815/816 form half-bridge drive circuit to drive the inverter transformer.
              I would check QI815, DI810, 811, 813, 816, and the parts around the Gate drive of the MOSFETs'.
              What DCV do you have on that main filter cap, 380~390VDC when TV is ON?
              BTW, CI839 is the commonly failed cap.
              • veikra
                • Sep 2012
                • 55
                • canada
                I had no short after replacing Q816. It's when it turned on that I got the issue. probably both side of the half bridge were shorted, replacing one solved the short, but only until the new mosfet turned on.
                I have 400VDC at the main filter caps with tv on.
                  You should have replaced both of the MOSFETs and inspect all the parts connected to the Gate pin.
                  • veikra
                    • Sep 2012
                    • 55
                    • canada
                    yes, I did mess up.
                    One question, the ST version of the 2N7002 is 200ma, the ON semi version is 115ma.
                    Do you think I can use the lower power On semi since the ST is backordered?
                      It depends on how much current is being used in that circuit. Do you know which section that Transistor being used in?
                      • veikra
                        • Sep 2012
                        • 55
                        • canada
                        yes, it is used to pull the gate of QI816 down.
                        Unfortunaly I don't know what kind of voltage comes out of the transformer to calculate the current.
                          That is the Gate discharge MOSFET for the power MOSFET QI816 so the pulse current can be quite high, I owuld stick with original spec of the Transistor.
                          Is that the only device get damaged?
                          It is tested bad?
                          I expect ZI805 to be damaged too.
                          • veikra
                            • Sep 2012
                            • 55
                            • canada
                            It is tested bad?
                            It exploded and chunks of it flew off
                            yes the zener , the mosfet as well as the 4.7 resistor.
                            The schematics only says 2n7002. it's when I looked for a replacment that I found they were different amp rating with the same number
                            • veikra
                              • Sep 2012
                              • 55
                              • canada
                              FIXED!
                              So the NCT was shutting down all the low voltage and both QI816 QI815 shorted. Not replacing QI815 blew QI816 and RI868 ZDI805 RI866 and QI814.
                              The original failure was likely Q815 Q816 then the thermistor. Rest is my own fault but fuck it, ive got to release some blue smoke once in a while.
                              I used the 115ma mosfets 2n7002 since I couldnt get the other fast. Tv set is on test and I'll report how they do.
                                Glad to hear you got it working.
                                When Power MOSFET shorted out the GATE drive circuit should always be inspected and tested at the same time, and if the GATE is driven by the IC then the IC should also be replaced at the same time since it is not worth blowing the new MOSFET due to IC that is damaged when the MOSFET failed.
                                The NTC is for inrush current limiter when the TV is first turn on, it will blow if the load is shorted.
                                The NTC is bypassed by the relay when the TV is turned on so make sure that the relay is closing and bypassing that NTC.
                                • veikra
                                  • Sep 2012
                                  • 55
                                  • canada
                                  yes, relay is working correctly. I doublechecked all the mesurements from the pads of all the parts removed this time. Saw some 150 Ohms, checked around saw the resistors and followed the traces to make sure. These mosfets cost me over 2$ each
                                  Tv has been running for 2 hours now. It starts cold with 2 vertical line when cold, but clears out after a minute or 2. Im not gonna fix that, flex ribbon, bga. Not worth the time.
                                  Keeping this one to myself, replacing a 40 inch samsung that's running a toshiba main board and half of another powersupply. That thing is a beaut!
                                    09-07-2024, 05:50 AM
                                  • String2016
                                    samsung np300e green screen
                                    by String2016
                                    I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
                                    07-26-2025, 04:00 AM
                                    09-06-2024, 11:40 PM
                                    09-06-2024, 08:40 PM
