LG 60PZ250T-ZB fault
  • David Lillis
    • Oct 2017
    • 5
    • Ireland
    Hi Everyone,
    I'm new here so sorry if I ask obvious or already answered questions.
    I have the above plasma TV since mid 2012 and its worked fine up until today.
    I'm getting what looks like vertical blue banding intermittently (only about 10% of the time, but I'm afraid of it getting more frequent), at other times I'm getting purple/blue areas and sometimes slight horizontal ghosting/dragging when I use the menus. I downloaded the service manual, I checked the Va and Vs voltages, they were very slightly high, so I reduced them, no change.
    While I had the tv open, I cleaned out alot of dust, while aware of static electricity dangers.
    One thing I thought was interesting was that I can make the fault temporarily go away or manifest itself by changing the screen brightness and it seem to either start or go away when the scene I'm watching changes as if certain screen images cause the problem, like the tv cant handle them..
    From the manual, the problem kinda looks like scan type mal-discharge which would indicate the y-sus board and/or the t-com board,
    The tv firmware is 3.13.33.
    I guess what I'm asking is that could this be a cable/connector fault or is this possibly the start of the end of the panel itself ?
    I can source both the y-sus and t-com boards on ebay.
    any help and suggestions would be very appreciated,
    Dave
  • tw2005
    • Oct 2011
    • 6458
    Re: LG 60PZ250T-ZB fault
    shut it down. pull the ysus and zsus out, have a very close examination of the solders particularly on thos large coils. Chances are they are broken hence the intermitency. Or keep using it and eventually the ZSUS will likely pop and short out the IGBTs.
    Images always handy of the display fault, common issues with these I believe though. Done a couple , both had blown ZSUS and broken joints onthe coils. Image issues are the early warning.
    • David Lillis
      • Oct 2017
      • 5
      • Ireland
      Many thanks for the rapid response,
      I've attached 3 pics, does this look like a problem you've seen before ?
      I seen several big copper like inductor coils on the boards, are these the ones you're on about ?
      One thing that surprised me was how hot the heatsinks get on the y-sus board, it would be better off with a low noise fan on it
      Dave.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Shut down the tv!!!!!
        Take off the back and remove the zsus and the ysus boards.
        Look under the boards where the big copper coils go through the board. Most likely cracked solder joints.
        I would touch up all the solder on everything that is attached to a heatsink.
        Check all solder joints just to be sure.
        • David Lillis
          • Oct 2017
          • 5
          • Ireland
          Many thanks for your reply.
          Wow!, it sounds like I might have dodged a bullet here !!
          I've the tv unplugged from the mains.
          I'm away from home from now until Friday so I wont be able to look at the back of the tv until then, when I do I'll will report back what I find. It will be left powered down for now.
          Many thanks,
          Dave.
          • tw2005
            • Oct 2011
            • 6458
            The ones I've seen were the ones where they were used until they went bang. I think that will be as we've suggested. Yes, if treated early should be good.
            • PlasMatt
              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
              by PlasMatt
              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
              09-20-2025, 06:50 PM
            • Rictech
              Panasonic SA-MAX770PU SMPSU board fault....
              by Rictech
              Hello everyone. 😀
              As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
              Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
              Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
              This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
              There are no devices that have exploded or otherwise show signs...
              08-26-2024, 01:05 AM
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
              ESR meter came to the rescue again today with a PLC I/O card fault
              by sam_sam_sam
              I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
              I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
              One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
              12-18-2023, 08:17 PM
            • Agent24
              What kind of fault causes this image error?
              by Agent24
              I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
              The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
              What's the most likely cause of this problem, does anyone know?...
              09-22-2025, 11:42 PM
