Vestel 17 PW05-3
  • barry wilkins
    • Aug 2009
    • 172
    Vestel 17 PW05-3
    Hi has any body got the correct diagram for this PSU fitted to Toshiba 19DL833B?
    The one you can find on the internet is wrong ,on this psu the 12volts and the 24volts are connected together.
    Barry Wilkins
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Vestel 17 PW05-3
    Post a picture of your power supply which would be helpful. The 12v and 24V connected together does not sound correct!!!
    Chek your diodes for short circuit. D709, D710, D712, D713 & D715
    Have you seen
    https://www.youtube.com/watch?v=6fSfLB9I2LM
    • heavymachines
      • Mar 2011
      • 1028
      ^ +1
      • France_53
        Vestel tv, how to flip the image?
        by France_53
        Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
        05-12-2024, 05:22 AM
      • FlailingEngineer
        Help with Bush Tv (Vestel 17mb95m Mainboard)
        by FlailingEngineer
        Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
        Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
        05-31-2023, 06:52 AM
      • massimomax
        Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
        by massimomax
        Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
        spero che qualcuno può averlo per riprogrammare eprom. grazie
        Post in English !!!
        I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
        02-28-2025, 07:27 AM
      • Adenitz
        Troubleshooting Vestel TV, has standby, but cannot turn ON
        by Adenitz
        I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
        Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
        Both boards are shown in the attached photos.
        What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
        12-27-2023, 03:43 AM
      • Bazilwrc164
        Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
        by Bazilwrc164
        I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
        The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
        I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
        If anyone can provide:
        • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
        • Or a compatible EEPROM dump
        07-23-2025, 12:15 PM
