Good day folks. I wrote a separate thread about this just in case someone had a brainy idea that would help me salvage a Samsung UE40H6400 which keeps rebooting every 10 seconds, but apparently the only thing I can do is swap out the whole mainboard. I found one, but despite being physically identical, it's listed as being for a 32 incher (UE32H6400), whereas my set is 40 inches (UE40H6400). The model of the board is absolutely identical and so is the panel, with the exception of the two numbers that denote the size (32, instead of 40)...should I go for it ? What do you guys think ? Would the board "adapt" itself to the larger panel or will I get issues ? It's not terribly cheap either, so I wouldn't want to buy it for nothing....
Replacing 40 inch mainboard with 32 inch mainboard
Re: Replacing 40 inch mainboard with 32 inch mainboard
Yes.....If the T-CON Bds are different but LVDS cables are similar.... -
It will almost always work if the panel size is the only difference.
If the panel model or manufacturer is different there is a possibility it will not work.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
The panel model number is identical aside from the size: mine is CY-GH040CSLV2H, whereas the one I want to buy only lists CY-GH032....no mention of the T-con whatsoever.Wattevah...Comment
I would take the gamble....It will work. Go brave...Comment
It's not MY TV, so I don't really care too much other than learning stuff - it's in my shop so I first need to check with the owner if they WANT a new motherboard in it - fairly pricey, including labour....Wattevah...Comment
This should be fine aslong they match other than the size...ive done this a few times with samsung boards and both times they worked flawlessly.. 32 inch board into a 40 inch and a 50 inch board into a 40 inch..you can also go into the service menu and change the panel size etc etcComment
Assuming you really have to do this, HOW would you do it considering the picture is not displayed properly ?
Again, ASSUMING the board doesn't play well with the different panel.
Wattevah...Comment
The exception is plasma TVs.
Panasonic - almost never can you swap A board for different sizes as it also controls panel. The panels have different discharge parameters (reset/init ramps, energy recovery capacitance, and peak discharge energy.) Wrong board can cause maldischarge or sustain board failure.
Samsung/LG - the 42" and 50" 720p sets use a different resolution. Also some Samsung late model plasmas integrate the control board function onto the main board, which locks that to the panel in the same way as Panasonic. Not aware of any LGs doing this, but they might do in some models, so watch out.Last edited by tom66; 08-21-2017, 02:36 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
This might explain why some people around here trying to repair various TVs still have the same issue even after replacing boards.The exception is plasma TVs.
Samsung/LG - the 42" and 50" 720p sets use a different resolution. Also some Samsung late model plasmas integrate the control board function onto the main board, which locks that to the panel in the same way as Panasonic. Not aware of any LGs doing this, but they might do in some models, so watch out.Wattevah...Comment
I've had an 50 inch HD LG plasma which main board was corrupted,the menu was clipping out but still readable,some screens were all diagonal-like(skewed 60º) and barely recognizable,but the service menu was intact!Tool and area option were set to a 32 inch model,just changed and it got fixed.
If something goes wrong you'll probably have display and will be able to see properly,so acessing the service menu and changing whatever is necessary will be an option,for your Samsung TV i say.Comment
I just noticed another difference, which I must admit I haven't spotted till now: the panel for the one I want to buy is advertised as CY-GH040CSLV7H, whereas mine has a 2 instead of that 7....it's like a game of "spot the difference", just with TVs
Wattevah...Comment
Where does this panel size option located? what should i choose after entering the service menu? ThxThis should be fine aslong they match other than the size...ive done this a few times with samsung boards and both times they worked flawlessly.. 32 inch board into a 40 inch and a 50 inch board into a 40 inch..you can also go into the service menu and change the panel size etc etc
i think , it will work ; i did it a couple of times by copying BIOS of 40 inch board to 32 inch board for another brand, if BIOS and main IC same in both boards , just swap BIOS ....ENSURE THEY ARE SAMEComment
Oh i see , what if i swap mainboard from the exact same tv and the only difference is the inch size do i still need to swap the bios too?
This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 07:20 AM
This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 07:19 AM
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 07:12 AM
- Loading...
