Samsung BN41-01955A with a short on CPU SEMS29
  • sn4k3
    • Oct 2016
    • 68
    • Portugal
    I have an board from samsung with a short on the CPU due a lightning that came via HDMI signal and broke the 10ohm resistor array and put CPU under a short. I have removed CPU and short has gone.
    Is it possible to put a new SEMS29 reflow it and board will work again or chip must be programmed somehow? Can't find the datasheet of the IC
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung BN41-01955A with a short on CPU SEMS29
    I don't think the chip would have to be programmed
    • sn4k3
      • Oct 2016
      • 68
      • Portugal
      So the program is inside other ROM chip and not the SEMS29 itself?
      As the SEMS29 is hard to find and buy thats why i ask, also can't find a datasheet to confirm...
      • diif
        • Feb 2014
        • 6978
        • England
        The SEM29 is a processor. No programming required.
        The program is in the TSOP48 and there's a SOIC 8 chip also.
        • dskall
          • Oct 2016
          • 2905
          • usa
          They look to be available though
          • sn4k3
            • Oct 2016
            • 68
            • Portugal
            Thank you, i will try to reflow it on place. Ordered 3pcs
            I will update once got news.
            Regards
              09-07-2024, 05:50 AM
            • jesterace
              Samsung UE46ES8000 Blown fuse but no other signs of short
              by jesterace
              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
              09-11-2024, 03:14 PM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
