LG plasma timing adjustment
  • Proxybox
    • Aug 2017
    Hi Tom66, on your guide to plasma it said you would post about adjusting timing. I did a search and didn't see it. I tried posting in that thread buts it's closed. Did you ever post instructions on this adjustment? I've tried all the options you listed to remove sparkles from my LG 50pk950-ua but without success. Adjusting any of the Va Vs or other 3 voltage adjustments as listed in the LG manual doesn't make a difference. Much appreciated. I did use a Fluke True rms multi meter.
    Re: LG plasma timing adjustment
    Timing is done on Yrr/Yfr adjustments on Y-sustain. Try adjusting those. Haven't ever been able to properly fix sparklies on LG panels though - it's a difficult one.
    • Proxybox
      • Aug 2017
      Thanks!!! Also for moving this thread to a new thread. Sorry about mixing it up.
      I did try the VSC and -Vy Adjustment on the Y-sus board. I believe that's the same as the Yrr/Yfr you mentioned? I couldn't recall the names when I responded originally but that's the ones I said were the additional 3 in addition to the Z-bias. I adjusted all those but the sparklies persist.
      Additional Information: I originally ran into the common problem on the LG's where the HDMI input's would no longer work. I found a local tech who took my logic board and 'fixed' it. He told me he replaced an IC. I installed it and everything worked peachy for about a month. After that point the sparklies starting appearing. Related? Do you think replacing the logic board with another refurbished one and perhaps the Y-sus board since I get both relatively inexpensively is worth a shot?
        -Vy and Vsc are not the same as Yrr and Yfr.
        Let's make sure the voltages are correct:
        See here:
        Check you have a PDP50R1 panel.
        Page 131: Make sure Vs & Va match sticker within 1V.
        Page 133: Make sure -Vy & Vsc match sticker within 1V.
        Page 137: Make sure Vzbias matches sticker within 1V.
        The Set_Up (Yfr) and Set_Dn (Yrr) adjustments are something we can tweak later. Ideally a scope would be used, but you can experiment with adjusting them carefully. But first, make sure all your voltages are correct.
        The main input board with HDMI ports has nothing to do with sparklies. Replacing the Y-sus board will not usually fix sparklies unless something is badly wrong with the Y-sus. This usually results in a nearly unwatchable image.
        • Proxybox
          • Aug 2017
          I adjusted all 5 voltages within the label specs. I was very precise.
          After setting I noticed no.change
          So.i started slowly turning pots and watching the screen with a mirror and seeing if sparklies disappeared. But nothing
          On a final try, after about 4 tries, i
          accidentally touched the setup pot when adjusting the last time. I tried to put it back to approximately where it started at but it was a guess. When I read I needed an oscilloscope to properly.adjust it I panicked a little. But the image didn't change or distort so in thought I was OK. However the sparklies persist.
            OK, so since the voltages are correct we can go from there.
            You need a static image that shows the sparklies well. Pause a DVR, DVD player, etc.
            Then adjust Set Up to the point where pixels start going DARK...i.e. not enough are lit, it will be one way or another.
            Then increase it slowly until the dark pixels disappear. Choose a point that is ideally before the sparklies themselves appear.
            Tell us what it looks like then...it may have a lot of dead pixels, so that is something that can be adjusted using the other potentiometers.
            • Proxybox
              • Aug 2017
              Update: The local tech, Arturo, I mentioned agreed to take a look at my plasma. This time I took the entire TV to him to examine. In all fairness he asked me to do that the first time but I didn't want to haul the opened pdp in the car and risk breaking it but now I know that would have been ideal because each board needs to be tweaked with others when repaired for voltage adjustments. After about an hour I returned and he had it running with no sparklies. I turned it off and let it rest awhile and they still didn't return. He said that the issue was still with the logic board and that he repaired it. He doesn't speak English really well but I think he resoldered items on the board. The bottom line is it's fixed and the sparklies haven't returned in over a week of regular usage.
              He showed me the boards he was sent from all over the US to repair. He's a great guy and works in a small workshop by his house in Los Angeles. I was lucky to have him local to troubleshoot the board. The other thing is he only charged me $20 since he worked on the logic board a second time. He shared his Bonanza page and he has an awesome reputation so here it is if others need board repair. http://m.bonanza.com/users/15774060/profile
              I called other techs in the area and one even told me the pdp was shot and to call it a day. Another said the logic board needed to be replaced so he gave me hope but it would cost $500 but with new parts from LG and no guarantee the repair would cure it.
              Thanks for all your help.
              • Mark R
                Marantz Model 150 Tuner "NULL" Adjustment..
                by Mark R
                I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
                Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
                12-30-2024, 03:18 PM
              • r-p
                Maldischarge-link that fixes it with replacing caps
                by r-p
                Starting this thread because Capkid doesn't seem to be reprogramming controlboards anymore (LG 60PZ950 with red maldischarge) and my game-plasma also has maldischarge (Hitachi 42PD3200). So I will grasp at straws to keep them running. I am extremely bad at throwing stuff away.
                Is there any merit to this link?
                Very short version: Specific caps seem to loose their capacitance and/or increase their ESR. This may cause the maldischarge. Replace them with better/bigger/newer ones and problem solved.
                From the limited knowledge I have on the subject, I think...
                01-21-2020, 05:16 PM
              • ArMaaN376
                Samsung PS51E550 Plasma TV
                by ArMaaN376
                I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                Opened TV cover & observed foll
                a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                How to confirm Y -Buffer board...
                06-19-2024, 04:05 AM
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
              • KYBOSH
                Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                by KYBOSH
                Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                No picture but you hear the TV static (white noise) playing loud and clear.
                The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                But it seems they didn't get too far and just left it.
                When I first took a look I was amazed at how pristine the inside looked.
                Its as if the TV had been in a time capsule.
                Caps looked like they were just pulled off the self.
                Copper coils had no sign of corrosion on...
                02-01-2023, 11:10 PM
