LG flatron-w2361v reset
  • CroTech
    Student
    • Dec 2012
    • 149
    • Croatia
    Hi all, I found LG Flatron W2453V at the dumpster, it had a white screen only, so I noticed a burned out SMD coil on the digital board and since it can not be replaced, I bought cheap board with controls, but this one was from LG flatron w2361v.
    The problem is that now, I have kind of a demo that shows half of the screen in one settings and the other different, it can be seen in the pictures.
    I am wondering is there a way to reset digital board eeprom or the board itself since my controls on the monitor are not working, only the on/off switch works (so, no menu, no nothing).
    Sorry for the photos, I will try to get it better once I get my camera back.
  • sheffieldyorky
    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
    by sheffieldyorky
    Hey there people
    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
    This is what I tried, but not in any order.
    Google
    YouTube
    BIOS
    Command Prompt (administrator privileges)
    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
    10-25-2025, 02:22 AM
  • odie34
    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
    by odie34
    I am a hobbyist (not a professional) so please be gentle...
    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
    02-18-2024, 09:11 AM
  • electrophoros
    LG Flatron W2361V PSU Troubleshooting
    by electrophoros
    Hi everyone.
    I am trying to troubleshoot this computer screen which went black and won't power on after a power surge.
    I have measured the output voltages and there seems to be proper voltage pressence on the 5V outputs, there is no voltage on the 22V outputs and I am unsure of what I should be measuring on ADIM, BDIM, EN and OLP.
    There also doesn't seem to be any voltage on the backpanel outputs:
    I have already identified and replaced two bulging electrolytic capacitors, and there is voltage after the fuse.
    07-27-2022, 07:37 PM
  • ictc
    Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
    by ictc
    I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
    Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
    The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
    02-25-2025, 12:15 PM
  • kotel studios
    ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
    by kotel studios
    Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
    Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
    I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
    12-14-2024, 10:48 AM
