OMG SAMSUNG UN55F9000 Ultra HD, SMART, 3D 4K
  • Frank29578
    • Apr 2019
    • 30
    • Nederland
    #141
    Re: OMG SAMSUNG UN55F9000 Ultra HD, SMART, 3D 4K
    this is the zip of the f9000 bin
    • ciine
      • Oct 2015
      • 87166391963
      #142
      I have two 55f9000 TVs and one 85s9.
      The motherboards are on the same platform but several hardware variants. From the service menu you can set both f9000 and s9
      the problem with me is that out of 6 mainboads 2 are good but with different hardware versions.
      The main problem is that all start but the ones with the corrupted software, display the busy hdmi3 port, do not find the programs in any band or any source connected through hdmi, but instead work on smart hub and youtube.
      Regarding sek 3500 cannot be connected to a faulty motherboard that did not bk to settings with original connect box
      go url
      • Michale32086
        • Nov 2011
        • 1453
        Two possible courses of action.
        1. Try to do a firmware update via the USB port..
        If that fails...
        2. Try removing the firmware chip from one of the non-functional boards and place it on the good board(s).. The firmware chip will likely be an 8 pin chip that looks like the one pictured. It will either have an ATMEL or WINBOND stamp on it..
        SOME firmware chips are of the shallow, thin and surface mount variety.. If that's what you have, I would not recommend trying to de-solder/solder it by hand..
        • ciine
          • Oct 2015
          • 87166391963
          #144
          The firmware for this model is in a 4gb emmc with 170 bga, it is hard to change.
          https://www.samsung.com/semiconducto...M4G1FETE-B041/
          go url
          • ciine
            • Oct 2015
            • 87166391963
            #145
            KLM4G1FE3B
            KLM4G1FE3B-B001
            https://cdn.badcaps-static.com/pdfs/...068de752c7.pdf
            I have sevice manual for u91a , f9000
            go url
            • soscomputer2008
              • Apr 2013
              • naples
              #146
              i have a ue55hu8500 with cyclic problem. with one connect connected you can hear the relay attacking and disconnecting, if you disconnect one connect the display lights up and the box connection icon appears. in box one connect I replaced gl852g because it was overheating and it was short but it did not solve the problem. the gl852g is for the operation of the usb ports. do you have a suggestion i can't find repair schemes or service manuals for this tv. I think all the tensions are present and I connect 12v on the one connect power pin the tv alone black screen and the relay does not go in loop.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4451
                • Italy - Milan
                #147
                Hi, i think this thread is for people with an F9000 series TV, you better start your onw thread to make no confusion to other people reading back contents for nothing. I wanna only to add an idea here after reading some past posts, the big problem here seem to be the firmware like my Italian forum reading says, the programming trough RT809F is not possible, only H model, there is one possible other way with connecting a pc through serial port, this needs a lot of hours and study to be made, but is the cheapest way and needs no firmware i think.. Bye bye..
                PS: i see now that there are on ebay the firmware chip on sale, emmc type.
                • gipmad
                  • Jul 2020
                  • it
                  #148
                  Originally posted by OCBSlimz
                  Would anyone happen to have the service manual for this. ?
                  I managed to do a clean dump of the the NAND chip and firmware chips if this would help anyone
                  Matt
                  Hi Matt, do you still have the dump? Can you upload it somewhere please?
                  • Edgar2018
                    • Jul 2020
                    • Mexico
                    #149
                    Matt
                    Please helpme.. i Need the nand dump
                    Un55f9000
                    And eproom dump
                    . Please.
                    • Ihsani
                      • Jun 2021
                      • 5
                      • Holland
                      #150
                      hallo
                      ik heb de eeprom software gevonden op internet
                      • Ihsani
                        • Jun 2021
                        • 5
                        • Holland
                        #151
                        hallo
                        • Ihsani
                          • Jun 2021
                          • 5
                          • Holland
                          #152
                          Ue55f9000sl
                          • Ihsani
                            • Jun 2021
                            • 5
                            • Holland
                            #153
                            Hallo,
                            Wie kan mij helpen bij tv UE55F9000SL .
                            de tv gaat de hele tijd aan en uit.
                            ik heb de eeprom geprogrammeerd maar zonder succes
                            • SoloROKI
                              • Sep 2021
                              • Sverige
                              #154
                              Originally posted by Ihsani
                              hallo
                              Where did you find it ?
                              Please post a link.
                              • SoloROKI
                                • Sep 2021
                                • Sverige
                                #155
                                This is indeed an interesting thread, however it suddenly got very quiet.
                                Did everybody solve the issues or got tired of trying ??
                                • hurxkens@telenet.be
                                  • Dec 2021
                                  • Belgium
                                  #156
                                  Is your problem solved?.....
                                  I have the same problem.......
                                  Thanx in advance...
                                  • matyka
                                    • Jan 2015
                                    • 179
                                    • Uk
                                    #157
                                    Hi, someone who knows what is the name/model for the mini connect box port please, mine have broken pins .
                                      Samsung Galaxy Book3 Ultra NP960XFH-XA1BE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA1BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA1BE boardview and NP960XFH-XA1BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 07:12 AM
                                      Samsung Galaxy Book3 Ultra NP960XFH-XA2FR Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA2FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA2FR boardview and NP960XFH-XA2FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 06:40 AM
                                      Samsung Galaxy Book3 Ultra NP960XFH-XA3BE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA3BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA3BE boardview and NP960XFH-XA3BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      Samsung Galaxy Book3 Ultra NP960XFH-XA3DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA3DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA3DE boardview and NP960XFH-XA3DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 06:38 AM
                                      Samsung Galaxy Book3 Ultra NP960XFH-XA2CA Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA2CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA2CA boardview and NP960XFH-XA2CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
