Panasonic TC-P42ST50B - 7 blinks after some time
    Re: Panasonic TC-P42ST50B - 7 blinks after some time
    BD8658Z, yeah it's got a thermal pad. Can't find a datasheet or even spare parts. Part number indicates Rohm.
    Might not be this chip - could be adjacent parts. It probably monitors: VF15V, VF5V (its output), and some kind of pre-unregulated rail, possibly 20V or so, which is used to generate VF15V. It may also monitor the HIZ signal from the A board, but this might just be an enable (makes sense because the output dies straight away after SOS7).
    • tw2005
      • Oct 2011
      • 6458
      Well, Hopefully you'll work it out. probably a ROHM product but unlikely you'll find much on it bit like those driver ICs
      • tw2005
        • Oct 2011
        • 6458
        4 pictures for you. Looking at this , wondering either ic725 or that optocoupler pc480 which grounds out the 5V high for shutdown( under normal condtions) and driven by ic725
          Very useful. Thanks! Where do you get these documents? I can't find them anywhere..
          "main_stop0" is not the final SOS7 apparently, there are other "post-causes" like Vad/Vscn overvoltage that can cause a shutdown. Will need to verify these. Shouldn't be too hard to figure out the exact source - question is will parts be available?
          I ordered the £16 SN board, but it would be nice to have two SN boards.
          Testing TPSOS7 shows that it is definitely the final fault trigger. It goes HIGH, which causes the SUS outputs to collapse, 250ms later the A board cuts the show off and we get 7 blinks.
          What's interesting is how quickly it cuts off, I think Panasonic have learned a lesson from the expensive repairs on '30 series which could kill buffer ICs. This operation should kill the power to every high-voltage component nearly immediately. Then there's only the AC-coupling across the panel itself from the SS board, but that shouldn't damage anything.
          Trying to figure out how to float my scope so I can do some floating ground tests, but I want to fully isolate it. It will run off 40V DC (just through the mains input, it has a very low input threshold!) but I have no way of easily making that isolated. Could use a bench power supply, but not sure what isolation looks like under high voltage and not really willing to blow one of those up to find out.
            Yeah, deffo main_stop0 causing the fault as it does exactly the same thing as sos7. Goes high and immediately drive outputs collapse.
              OK, so I was brave (or stupid - I'll leave it up to you) and decided to float my scope. Modified a power lead to remove the earth so I could connect the scope to anything floating. This lets me probe the floating ground side with the scope.
              Doing this, I was able to verify the F20V, F15V and F5V are all fine before and after the fault. F20V is unregulated, about 21V when picture is bright and 17V when it's dark, but this doesn't seem to trip the circuit and the F15V is always steady. The reason it varies is probably because the Vscn/Vad are regulated but not auxillary rails. Nothing wrong with this.
              I am now of the belief that the fault is optocoupler PC16480. I have checked the PC pin of the IC16725 and that is LOW throughout the fault. This indicates that it is driving the LED of '480 which should keep main_stop0 low. However, main_stop0 does not stay low, even though the PC pin is still low. So, either the LED or the transistor inside the optocoupler has failed in a way that causes the fault when it gets warm.
              I'm now digging around a few boards to see if I have an optocoupler that'll fit, and will see if this fixes it.
              If this is the cause of the fault I kinda can forgive Panasonic...this will be one of those "part-per-million" type failures that still occur even with good engineering, and credit to them the circuit is designed in such a way that should the part fail it trips a fault. The actual failure may be something related to a die bond failing under temperature or a damaged LED/phototransistor die.
                Definitely '480. Soldering iron on it causes TV to die almost instantly but not the same for adjacent parts, so it has become heat sensitive somehow. Really odd, but fascinating failure!
                  Replaced the opto and reinstalled the board, but for the life of me I cannot get the panel connectors back in and aligned properly - any tips from anyone who has done this? Every time I try, the bottom edge comes out slightly.
                  • flocko
                    • Nov 2012
                    • 1121
                    #29
                    I find that if you leave the board floating on the fixing screws till you get the ribbons lined up it helps, if you can see any of the gold ribbon contacts outside the connectors they are not fully home, when you are happy then crack up fixing screws
                    • tw2005
                      • Oct 2011
                      • 6458
                      Nice, yeah at a guess I would have swapped out the opto if I had something handy. can't help with the ribbons , never touched a 50 series. I'm presumuing it's a thin model and the re's no room to get the fingers in? The GT30/VT30 are two models I'd hate to remove the buffers. Bugger it's a SN board
                        Bingo, thanks Flocko for the tip, loosening the screws helped get the first one in, then I tightened them progressively as I got up the board. First time was pretty close, only had to adjust three ribbons. Picture is perfect now. Tried a hairdryer on the affected area for a good few minutes and no 7 blinks. Bonus: the opto was free, from a scrap Samsung Y-main board. Doesn't quite fit but it'll do the job!
                        Thanks everyone. Another TV saved and just in time for the girlfriend to visit tonight .
                        • flocko
                          • Nov 2012
                          • 1121
                          #32
                          just need a little movement on the board to get them to fall into place , nice fix you would have been lucky to find it, without the scope. Have a great time with your girl tonight dont spend it all watching TV, I am sure you can think of better things to get up to
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            Originally posted by tom66
                            I'll try monitoring SOS7 and sustain waveforms on the scope, if there's a time delay between one and the other it might clue me into what's going bad where. I'm thinking main board right now - probably BGA solder - ugh. But maybe I can borrow the reflow oven at work.
                            Told you on whatsapp ages ago that these are known for bga issues mate.
                              In this case it seems to be fine. I'd expect Panasonic to have got their act together with BGA failures.
                              • Andre Gilbert
                                by Andre Gilbert
                                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                11-20-2024, 08:52 PM
                              • jm1234
                                Panasonic plasma TX-P42ST50 - 6 blinks
                                by jm1234
                                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                I checked that board for any obvious faults...
                                05-22-2024, 06:59 AM
                              • Alicat
                                Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                by Alicat
                                Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                Model number is TH-50PZ85U
                                Power comes on and the red power light stays on solid.
                                Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                I also hear a few clicks.
                                I also think my parents said there was a thunderstorm and the TV failed after that.
                                Section 6 in the service manual talks about power and no screen,...
                                10-30-2024, 10:09 AM
                              • CrewmanRedShirt
                                Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                by CrewmanRedShirt
                                Hello all,
                                As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                07-13-2024, 11:02 AM
                              • nobbnobb1
                                Panasonic TC-P50U50 Powers Off - 8 blinks
                                by nobbnobb1
                                I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                                2x DG302 (Q16051)
                                2x RF2001 (D16041)
                                2x 5.6 ohm SMD resistor
                                1x BD8694 IC
                                I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                                03-21-2023, 08:33 PM
