Samsung UE32D6530 going into standby
  • Norman1
    • Jun 2017
    • 77
    • Uk
    Hi guys, I have a Samsung that switches on,picture comes up fine, then 30 seconds later it switches into standby. Checked all the usual standby settings in the menu. Tried heating up the boards but no good. Any sudgestions?
    Many thanks.
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung UE32D6530 going into standby
    Service menu, factory reset?
    • Norman1
      • Jun 2017
      • 77
      • Uk
      When I go into the service menu it won't move or select anything,,,mother board?!
      • maxvalutech
        • Dec 2014
        • 804
        • australia
        Comes on, warms up, shuts down. Cold solder joint. Component turning off. Try cooling the main ?
        • Norman1
          • Jun 2017
          • 77
          • Uk
          I havnt tried cooling it, I will give it a go and let you know
            09-07-2024, 05:50 AM
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • ChristianBr01
            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
            by ChristianBr01
            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
            04-23-2025, 01:48 AM
          • Kaar3l
            Samsung QLED QE65Q7FNAT only standby light
            by Kaar3l
            TV: Samsung QLED QE65Q7FNAT
            PSU: BN4400940A
            MB: BN94-12832K
            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
            09-24-2024, 01:35 PM
            09-06-2024, 11:40 PM
