Samsung PN5D550C1F 5 second/1 second blink
  • philtvman
    • Jun 2016
    • 94
    • America
    Looking for some advice with this unit, it's been driving me crazy.
    TV is having the error in which it does not turn on, but the green LED on the control board repeats lit 5 seconds, off 1 second. I figured it was probably either the X and Y boards and was trying to get it out of my hair pretty quick so just ordered one of each. Both came with VS shorts, which was fun.
    Anyway, I've tried unplugging X and then unplugging Y. The TV will blink the normal 1 second interval only if all ribbons and connections to X and Y are unplugged. Otherwise it does the 5/1 blink.
    These are the listed parameters:
    VS - 207
    VA - 58
    VE - 80
    With all X and Y connections disconnected, I'm getting all good readings. I did notice that PS_ON between power and main/control boards jumps to 177 volts with the unit turned on, 2.9 with unit off. I'm not too familiar with what the nominal on reading for this is.
    With the Y connected, I'm getting relay click and:
    VS - Spike to 206 then drops
    VA - Spike to 60 then
    VE - Spike to 105 then drops
    15 Volt to Y Main is good
    This is the same with Y and X both connected. I tested Y Buffer for shorts, but it checked out good. Can't find any shorted MOSFETs or diodes on Y or X either.
    Any help as to where I should go from here would be appreciated. I'm just really getting into this stuff, so trying to learn and absorb all I can.
    Thanks!
  • philtvman
    • Jun 2016
    • 94
    • America
    Re: Samsung PN5D550C1F 5 second/1 second blink
    Anybody wanna take a stab at it? Model is PN51D550C1F. Couldn't find any shorts on Y Buf, Y Main, or X Main. Voltages drop to 0 with Y plugged in, are okay with nothing plugged into power board. Would the TV detect the X Main not being plugged in and shut itself off? Just trying to find which board is bad. I've ordered a new power board, Y Main, and X Main so far. Y Main and X Main both came shorted.
    Any ideas?
    • maxvalutech
      • Dec 2014
      • 804
      • australia
      Your testing has one strange result in that ps-on normally 5v dropping to nought when activated . There may also be a vs-on to measure it goes the other way but in any case all seems to be working. While the tests indicate y or x problem I have seen one post where power board was the problem. From around 2011 Vs etc only stay on for about 3sec as protection kicks in.Samsung Tech Talk late 2010 into 2011 has a plasma tutorial - Google it if interested.
      • maxvalutech
        • Dec 2014
        • 804
        • australia
        If your post gets to 3rd page from latest page your chances of input to your problem will reduce. Samsung mainly Ysus at fault.
        • tw2005
          • Oct 2011
          • 6458
          Try this guide. Sounds like th eproblem is still to do with the x or y but I thought these later sets had issues with Xmains. And yes a Max mentioned , disconnection of either with shutdown Vs.
          • terry locke
            • Sep 2017
            • canada
            i have the same tv it comes on fine then shuts off after 2 mins ive replaced the y and x mains nothing changed i tried a powersupply but the used one i got wouldnt even turn the set on vs and va are reading good til the set shuts down can a logic board cause this issue or should i keep looking for a power supply there like hens teeth lol
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              you could try running the test patterns. disconnect the lvds that goes to the main board and on the control board, jump pin 3 and 4. this should bring up the test patterns. let it run and see if it stays on.
              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                09-07-2024, 05:50 AM
              • Asraf Atb
                Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                by Asraf Atb
                Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                01-27-2025, 05:02 PM
              • JSin21
                Compatibility of main boards between different variations of samsung MU6100
                by JSin21
                Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                I have Samsung Smart TV UA65MU6100WXXY version DA01
                Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                11-27-2023, 04:54 AM
              • elpatxi_bcn
                Samsung HG75EJ690UB Hotel TV, change main?
                by elpatxi_bcn
                Hello!
                I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                05-19-2023, 03:21 AM
                09-06-2024, 11:40 PM
