Unusual fault on a Sony 40v3000
  • chrisB47
    • Aug 2016
    • 13
    • England
    Just thought I would post this fault up as it is a bit of an oddball and this write up might help someone else in future. I certainly hadn't heard of a fault like this before, but maybe you guys know different.
    The fault was that the picture appeared to be split down the middle and the left hand half of the image was in reverse. Also the screen was not giving a full width display. The colour was fine and on trying a menu setting the menu also displayed back to front on the left hand side.
    I tried a factory reset, but the fault remained.
    I figured the fault must be the tcon board as the menu was back to front, and a replacement tcon did indeed cure the problem.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Unusual fault on a Sony 40v3000
    Didn't get a picture of screen did you?
      LCD LED TV Service Menu Codes
      ALL LCD LED TV SERVICE MENU CODES
      Service Menu Code with Board Name
      China Universal Board / Jumper Board Service Menu Code
      Changhong Ruba Service Menu Code
      Ecostar LED TV Service Menu Code
      Orient LED TV Service Menu Code
      Haier LED TV Service Menu Code
      TCL LED TV Service Menu Code
      Samsung LED TV Service Menu Code
      LG LED TV Service Menu Code
      Videocon LED TV Service Menu Code
      Supra LED TV Service Menu Code
      Toshiba LED TV Service Menu Code
      Symphony LED TV Service Menu Code
      Veste/ LED TV Service Menu Code...
      10-31-2024, 03:58 AM
    • sickboy
      Strange CRT Fault (Sony Trinitron M1410U)
      by sickboy
      This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
      11-10-2024, 05:02 AM
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-06-2024, 05:27 AM
