Samsung PS50Q7HG help identify diodes
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Hi Guys, if you could please help me identify these diodes. I have searched endlessly with no joy.
    The fault area was found (photo3) whilst checking for shorts.
    The faulty diodes: zener diodes 5024 5023 5017 & 5016 (previous repairer)
    1x 4.5 zener 1x 5.8v zener 1x 1n4148 1x burnt
    The good diodes: zener diodes 5022, 5021, 5019, & 5018. (photo 4)
    The zeners have orange, brown, & green bands (3.1v?) (from the cathode reading left to right. (have searched for col band identity/ nothing specific)
    The F46F diode D5024 (incorrectly marked?) next to the faulty group didn't measure faulty but was removed for a better check. (gone awol/ suspected missing in a clean up...
    I have looked on my salvaged boards, and found similarly marked diodes (F46
    A, and with every other numeral & letter but no F46F)
    The set was tripping with the shorted diodes in, BUT, runs with them removed? protection?
    Please can you help me identify these diodes (both D5024 & the zeners).
  • tw2005
    • Oct 2011
    • 6458
    Re: Samsung PS50Q7HG help identify diodes
    i'm thinking D5024 will be the same as D5023. I also think the code is F4, the bottom 2 characters will be the production code, they also look like fast recovery rectifying diodes.
    http://pdf1.alldatasheet.com/datashe...TC1/FRS1G.html
    • Hamie
      • Apr 2014
      • 1383
      Have you seen in this video?
      https://youtu.be/R5mYKAgMoB4
      • Grunder
        • Jan 2016
        • 323
        • south africa
        Thanks tw2005, was able to lift one off another board, and get the set going.
        • Grunder
          • Jan 2016
          • 323
          • south africa
          Excellent, now why couldn't I find that!? exact symptom, mine was just the upper set of diodes.
          Fitted 3x 36volt zeners, and the F4 that tw2005 suggested, and hey bingo! up & running. To think of the time wasted trying to identify the components, whilst the answer was right here! literally a half hour versus half a day. Gracious Amigos.
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
          • dazzystar
            Samsung BN44-00517C PSU...identifying these zener diodes
            by dazzystar
            Does anyone know what value these zener diodes are please on a Samsung BN44-00517C PSU board?
            01-13-2024, 03:28 AM
            09-07-2024, 05:50 AM
            09-06-2024, 11:40 PM
