Panasonic 42GT30. TNPA 5330AB 7 blinks.
  • gatsu
    • Jan 2017
    • 11
    • Russia
    Hello guys!
    I have trouble with SN board.
    As usual i replaced q531+ic502, 3RJPs, RF1501, F131 (q401,402,403) and DAF30. No luck. I heard some hiss sound and then get 7 blinks back. All fets are dead.
    Replaced again. No difference, fets blowed up again.
    Next time i used 75w light bulb in series with Vs supply as Alastair E recommended in another thread.
    Replaced FETs again. With bulb i fried only Q621,622,623...
    Next time i replaced these F131 + Q762.
    At first power cycle i got 7 blinks but no chips shorted.
    At second try i fried Q621,622,623 again...
    Can you advise something?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic 42GT30. TNPA 5330AB 7 blinks.
    I'd check , driver ICs, resistors, check the panel output buffer ICs are not shorted, and have you used these parts before and did they work? 30F131, I'd expect all are fakes from china, I went from having things working to stuff blowing up and was due to bad parts.
    • gatsu
      • Jan 2017
      • 11
      • Russia
      Gate resistors is ok, diodes is ok, driver ic's seems ok (i don't know how to test eight pin driver), buffers seems ok - no shorts. I used these chinese F131 before on another TVs with no problems. May be a good luck, i don't know... Very strange.
      • gatsu
        • Jan 2017
        • 11
        • Russia
        Help me guys. Problem with another 5330. Replaced rjp's, 131, Q531+ic502.
        TV powered on and worked for 3-5 minutes, then loud pop - Q423 cracked. 3rjp and 3 f131 shorted. Others seems ok.
        Replaced those 6 fets, tried to power on, fets died instantly, tv didn't power on :
        Replaced 3 rjp and 3f131.
        there is something wrong with dg302 readings...
        For Q441 I get strange readings (multimeter in diode mode):
        Red wire to G, black to E - 563 ( on working board I get rising till 1950)
        Black wire to G, red to E - 600 (on working 678, seems ok)
        Black to GND, red to G - 1024 ( on working I see rising)
        GND to E - 324( on working 355, seems ok)
        I replaced dg302 - same readings.
        Didn't try yet to power on. I think fets will die again because of those strange dg302 readings.
        Any thoughts guys?
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          There are NO RELIABLE 30F131 on ebay anymore!
          Please check this out and also search this forum about fake items. I had the same problem.
          http://alpengeist-tvrepair.blogspot....ansistors.html
          Use FGD4536TM but be carefull , some are also fake.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Ps stop using the items because the parts are blowing up and you get black traces on the board. ( traces blow up ).
            The hiss you are hearing is small fire under the fets , i had the same.
            Please remove the cable from the SC board and turn on the TV. Measure the voltage going to the SC board.
            It starts with 207V with the blinking led and when it has processed all the info it will go to 215V before shutting down to 7 blinks. ( Because sc board is missing ).
            These 30 series all use 207V when you first turn on the tv and full operation is 215V.
            • gatsu
              • Jan 2017
              • 11
              • Russia
              There is no visible damages, or black traces yet, only popped rjp . I just wonder why DG302 readings differs...why resistance is not rising now (GND-->G). Maybe some little component died on the circuit. Any thoughts?
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                No , i repaired many of these boards. In the beginning i had alot of problems simmilar like yours , i even rebuild this board almost from scratch. ( resistors , diodes etc ). In the end my failures were deu to BAD PARTS FROM EBAY!!
                There are a few parts that blow on this board. 6 fets and 2 ic's + fuse and 2 transistors on powerboard.
                6 fets ( 30F131 and RJP30H2A ) + 2 small ic's is standard repair. Replace them all for FGD4536TM
                DG302 under heatsink does not read short but is actually dead! Replace both of them.
                Shoted DG302 will give 6 blink error or a green led that immediately lights up on SC board or 7 blinks.
                RJP63G4 ( bottom board , near c boards ).
                DAF30 only reads short because of the FETS that are shorted. Same for RF1501.
                Also check for blown diodes and ic's in the middle section next to the big capacitors. These will blow because of the bad parts.
                You have 95% sure bad/fake parts from ebay. Take some alcohol/aceton and see if you can remove the marking/logo on the FETS , a good part will hold its marking , on a bad part the marking will vanish.......
                Show us a picture of the parts please
                • gatsu
                  • Jan 2017
                  • 11
                  • Russia
                  =) I checked all big fets, diodes, and driver ic.
                  D401,D641,D642,D481,D482,D421,D643 - ok
                  Q621,622,623 - ok
                  q521,501,762 - ok
                  q531 and ic502 already replaced.
                  gate resistors - ok
                  q600,601 - ok
                  q661, q660 - ok
                  all buffers is ok
                  yes =-) i use cheap chinese parts from AliExpress. Repaired about 7 tv's - no problems for last year. I agree there is some % bad ones... Maybe now i'm out of luck =) But i doubt about it.
                  i repaired 5349AB recently with dead q40x, q42x, q62x + Q600, Q661,Q660. same parts, no problems.
                  I replaced both DG302, but i hesitate to try... because of strange readings.
                  normal sn board readings - https://drive.google.com/file/d/0B0u...JXOU55VHc/view
                  bad one with replaced DG302 - https://drive.google.com/file/d/0B0u...VnMkt3emM/view
                  i would not try until i figure out the cause of that ...
                  Any thoughts about it?
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    After each short you probably need to replace the driver gate ic and transistor again. Depends a little on the parts used. Im still pretty sure you are using bad parts because there are no good 30F131/RJP30H2A on ebay , especially the cheap ones from china. Trust me , i threw away 250+ of them.
                    There are also fake DG302 parts from china. There are some threads on this site about these parts....use the search button.
                    Please take some alcohol/aceton and polish the markings/logo on the parts and see if they stay or vanish a little. A good part will show very bright white marking , has cuts on the edges of the FET and has a deep circle. A small circle or no circle is bad part.
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      Also the 30F131 on every part must be stamped the SAME way. So the stamp has to be written in a straight way.
                      Sorry , the original 30F131 is not made anymore and they used some other parts. Cleaned the marking and replaced the marking with 30F131/RJP30H2a.
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        Also the hiss is coming from the FETS above the capacitors. The "FETS" used cant handle the load. Again , check the link i gave you and see how he measures the parts.
                        If you are still 100% sure your parts are good then do as i said:
                        Remove the powercable and sc20 cable. Black prope on chassis and red prope on SC11? ( Connector going to sc board ).
                        Turn on the tv , you must measure 207V when the led is blinking and then it changes to 215V and shuts down. If you get a huge peak then your PS is faulty and blowing up the sc board.
                        • gatsu
                          • Jan 2017
                          • 11
                          • Russia
                          Just tested PSU. 204 ---> 214. I think it's ok
                          Can faulty IC502 kill FETs? Or just 6 blinks?
                          Did you see videos with Q441 measures? I replaced it with another - no difference.
                          still wrong measures compared to working SN board.
                          i wonder which component caused that?
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            No that ic wont kill the fets , it will shut down with 6 blinks usually.
                            So did you test the parts with alcohol? Can you show us a picture of the parts you are using?
                            • Andre Gilbert
                              by Andre Gilbert
                              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                              11-20-2024, 08:52 PM
                            • Biruslapio
                              Panasonic P58V11B 8 and 12 blinks error "fix"
                              by Biruslapio
                              Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                              Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                              04-13-2021, 07:13 AM
                            • jm1234
                              Panasonic plasma TX-P42ST50 - 6 blinks
                              by jm1234
                              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                              I checked that board for any obvious faults...
                              05-22-2024, 06:59 AM
                            • Alicat
                              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                              by Alicat
                              Stopped by this site trying to fix my parents Panasonic Plasma TV.
                              Model number is TH-50PZ85U
                              Power comes on and the red power light stays on solid.
                              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                              I also hear a few clicks.
                              I also think my parents said there was a thunderstorm and the TV failed after that.
                              Section 6 in the service manual talks about power and no screen,...
                              10-30-2024, 10:09 AM
                            • CrewmanRedShirt
                              Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                              by CrewmanRedShirt
                              Hello all,
                              As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                              07-13-2024, 11:02 AM
