Panasonic TC-P42U2 - no click...no blinks
  • ultimatt
    • Apr 2015
    • 29
    When plugged in will not turn on...no click no blinks.
    Suspect it is the A Board...what is the procedure to troubleshoot to confirm A Board is bad?
    Thanks.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic TC-P42U2 - no click...no blinks
    You say no clicks when plugged in. Do you also get No clicks even when you press the Power button to turn it on?
    • ultimatt
      • Apr 2015
      • 29
      yes...no click when plugged in and power button does not click or do anything...also cannot generate click with remote
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        PSU bad then....Check fuses, power cord, etc.
        • ultimatt
          • Apr 2015
          • 29
          I don't think its the PSU...fuses check good and I'm getting power to the board.
          Based on what I've read here and elsewhere I think its the Main or "A" board that is bad.
          • ultimatt
            • Apr 2015
            • 29
            Would anyone happen to have a Panasonic TXN/A1LJUUS / Board Number(s): TNPH0831AG main board they would like to sell?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Apparently Main Bds for these 2009 TVs are hard to get...I am looking for a TNPH0800 2A Main Bd for a TC-P42X1....Just can't find any at all.
              • madlee357
                • Jul 2014
                • 6
                • florida
                this mainboard is expensive i just junk it s bought a new tv. the money u spend on this part u can get another tv. panasonic parts are expensive.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Originally posted by madlee357
                  bought a new tv.
                  What did you get?
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Are you getting the std-by 5V when you plug into ac?
                    • Andre Gilbert
                      by Andre Gilbert
                      11-20-2024, 08:52 PM
                    • Biruslapio
                      Panasonic P58V11B 8 and 12 blinks error "fix"
                      by Biruslapio
                      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                      04-13-2021, 07:13 AM
                    • jm1234
                      Panasonic plasma TX-P42ST50 - 6 blinks
                      by jm1234
                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                      I checked that board for any obvious faults...
                      05-22-2024, 06:59 AM
                    • Alicat
                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                      by Alicat
                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                      Model number is TH-50PZ85U
                      Power comes on and the red power light stays on solid.
                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                      I also hear a few clicks.
                      I also think my parents said there was a thunderstorm and the TV failed after that.
                      Section 6 in the service manual talks about power and no screen,...
                      10-30-2024, 10:09 AM
                    • CrewmanRedShirt
                      Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                      by CrewmanRedShirt
                      Hello all,
                      As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                      07-13-2024, 11:02 AM
