Sony TV overscanning
  • pentium
    • Mar 2006
    • 2778
    Damnit, no!
    Everything seems to be breaking down on me now. Anyways, today out of the blue while I was browsing the net on my PS3 (the last computer that I still have running) the tv started to overscan. It was not much but it forced me to drop my resolution so that I could see my scrollbars again and now I'm getting a buzz through the audio. The tuner packed up on it last year and I have been using it as an S-video monitor for my home theater ever since. It's a 27" Sony tv (rather not pull the thing off the shelf to read the model off the back but it does have PIP and front inputs) if that is any help.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • Wizard
    • Mar 2008
    • 2296
    Re: Sony TV overscanning
    Width or height?
    27" sony TVs are FAMOUS for bad solder joints. FIX IT NOW or that horizontal transistor go dead and shot the power supply if that one uses seperate PSU.
    Cheers, Wizard
    • pentium
      • Mar 2006
      • 2778
      I had a feeling it was a cold joint issue after letting the TV cool down for a while and turning it back on to find the problem gone until it warmed up. I'll tear it open tomorrow and go over it with the iron but this looks like a goox fix. As for the tuner....I still wish I could get that to work. I would rather play my Atart 2600 on this and not my Performa 5200 (it has a tuner installed).
      Find Nedry!
      • weirdlookinguy
        • Sep 2007
        • 1638
        Resolder any and all joints around the flyback, the HOT, the transformer near the HOT, and anything heatsinked. I had a Sony monitor go out because the transformer feeding the HOT had cold joints.
        • Wizard
          • Mar 2008
          • 2296
          NOW or leave TV unplugged till you get around to it to fix.
          Cheers, Wizard
          • pentium
            • Mar 2006
            • 2778
            After a lot of grunting and straining to get tv into the shop it has been fixed. It seems better now.
            Find Nedry!
            • Wizard
              • Mar 2008
              • 2296
              did u do everything in horizontal circuits including the horizontal driver circuit (that grey box transformer) and coils? Also the one vertical IC pins.
              HAVE a helper to move that damn TV.
              Cheers, Wizard
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                that set is a 2 person move.
                that is unless you want a destroyed back.
                as for the solder joints there will be a ton of them.make sure you get them all before running it any more.
                as a bonus if you pull the tuner and i.f module you will find even more busted joints esp on the grounds to the can.
                do it right the first time or there will be a bunch of parts to replace when it goes BANG!
                • Wizard
                  • Mar 2008
                  • 2296
                  kc8adu is right. Interestingly, I haven't yet to see bad tuner due to solder.
                  But IF module yes in very old Sony sets.
                  Sony made awesome tuners that can pull in real weak signal.
                  MX048 or something like that is PRICY. Especially those that have two transistors in one package. What on earth what Sony was thinking? :P
                  Cheers, Wizard
                  • pentium
                    • Mar 2006
                    • 2778
                    I went and soldered whatever I could that looked like it was likely to have a cold joint. The more high voltage stuff was also done after it was discharged using a ground lead, a resistor and a screwdriver (and me wearing a glove because I got zapped once before).
                    Find Nedry!
                    • Carlos#2003%
                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                      by Carlos#2003%
                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                      02-15-2024, 07:52 PM
                    • dkneyle
                      Sony KDL-46HX850 Can't upgrade/update firmware
                      by dkneyle
                      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                      09-25-2024, 10:44 PM
                      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 05:27 AM
                    • Nevillet
                      Sony HiFi Tuner loosing saved stations
                      by Nevillet
                      Hi All,
                      I have a 20+ year old Sony ST-S320 tuner that 'forgets' saved staions from memory. When I opened the case I was hoping to find a battery that could be replaced - but none was present.
                      I've attached the service manual. Can anyone point to where I should be looking to fix this problem?
                      Many thanks.
                      https://www.badcaps.net/forum/attach...1&d=1635359677...
                      10-27-2021, 12:35 PM
                      Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                      This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                      09-06-2024, 05:30 AM
