Samsung U32EH4003 problem.
  • HellasTechn1
    • Sep 2015
    • 176
    • Greece
    Re: Samsung U32EH4003 problem.
    Originally posted by budm
    There is label for the LED output Voltage under load, I cannot read it due to poor quality pictures.
    Where exactly on the board ?
    Why when i apply 3V to each individual led it lits at max brightness ? If they where 6V led's then they would not be able to lit at all with 3V applied on them.
    It is not only that i have tried 27Volts on each led strip bit also i tried all LED's individually with 3V from my bench psu.
    • HellasTechn1
      • Sep 2015
      • 176
      • Greece
      Originally posted by dick_barton
      Thanks for those. Photo 2 says your led string driving voltage is 65V @ 450mA so the leds are 3V leds.
      That makes sense. So are the 180V i get normal ? could it be droping to 60V under load ?
      note that in serries all LED's must draw equal ammount of current right ?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        The voltage adjusts itself to supply the fixed current (450mA) as set up by the constant current circuit in the Led Driver IC.
        So voltage is variable but current is fixed.
        • HellasTechn1
          • Sep 2015
          • 176
          • Greece
          OK i undertand. Thank you all for your Useful advices and comment's. They are always welcomed.
          I will have to stand by for some new LED's. If i get it right i will all let you know !
            450mA is quite high so the replacement LED should be rated higher than that, since they are using only 18 LEDs to light up 32" screen it is using lots of current more than usual.
            But again, it looks like they are cutting down the cost of building the TV.
            BTW, what is the Voltage rating of the cap CM807? 250V?
            • te71se
              • Jul 2021
              • Canada eh
              #26
              hi all sorry to bump up an old post but I came across this using my google-fu powers.
              I have a Canadian market UN32EH4003FXZC with BN44-00664A power supply board and DF320AGH-R1 made in China panel that I trash picked from our recycling room. It powers up makes sound and I can see video by shining my phone flashlight through the screen. I thought ok easy it's just some bad LED backlights but when I tested the output voltages of the power supply I was getting results that seemed to differ from others.
              The CNL802 connector reads:
              1: D+
              2: S-
              3: NC
              4: S+
              5: D-
              On pins 1 & 5 (D+ & D-) with or without the LEDs connected I get 170V, and on pins 2 & 4 (S- & S+) I get 0V.
              If I measure across chassis ground I get the following:
              Pin 1 D+ 172ish V
              Pin 2 S- 155ish V
              Pin 3 NC nothing (obviously)
              Pin 4 S+ 150ish V
              Pin 5 D- 0V
              Do these readings seem normal?
              There is a slight brown discoloured portion of the power supply board around diode D9801C which I guess is a little concerning.
              Is there an easy way to test if this power supply is bad for sure? I don't have a LED tester etc though I imagine if the power supply has been putting 170V across LEDs expecting 65V then I probably have some burnt out LEDs too.
              • neilc6
                • Nov 2015
                • 1550
                You probably have a lot of bad LEDs. Here's a pic of a UN40H. The diode could be shorted but easy to test with a multimeter. You can also test each LED individually with the multimeter in diode mode. Fairly easy to work on a 32 in TV though it's not worth much. An open LED will cause the circuit to be at the max rated voltage printed on the silkscreen for the board.
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
