i got a 5351am sc that was working fine. i decide to just pull the buffers plugs and jump sc50 for a quick buffer diagnosis before i go to bed.
there was a loud pop then i notice ic 748/mip 391 along with front row igbt's shorted but did not pop.
center one in row closest to buffers 30f131,q623 read 19.00 ohms, i tested in diode and ohms there is 19-20 ohm short across sc2!
now i need to know if i just replace the ic 748/mip 391 ,30f131 ,q623 will it not pop again
i found the 20 ohom short on the ic 748 the correlates with the 30f131.
i removed the center igbt, 30f131,q623 and i reads good but started poking aorund the ic and found the 19- 20 ohoms.
unless im reading the 20 ohm resistor
the first row closest to buffer all still reads 00.19 short after removing center 30f131 q623.
i tested all resistors and diodes to test within spec.
the short on sc2 is gone since i removed the ic 748 and the pins cor-late with it
