Toshiba 50L1350U - Dual Image/Horizontal Shift After Power Outage
  • caibbor
    • Mar 2017
    • 5
    Toshiba 47" (I think) TV
    Model 50L1350U
    Chassis Unkown (pictures included)
    This happened right after a day of power outages, so I presume there was a surge. It worked fine for the duration of most of a movie after the outages, and then started doing this. Everything seems to work just fine except for the "shiftiness" which you can see in the pictures. This happens to the OSD stuff as well as the movies. Happens with HDMI as well as analog RCA input. Nothing else seems to be amiss.
    I already opened the back to check for any fuses or burnt looking components. I have a multi-meter and a soldering iron. Not afraid to get my hands dirty on this one (I am a PC repair tech, never worked with TVs before). There is a fuse in the back, but I'm not sure how to tell if it's bad.
    If it were a computer, I'd point at the video chip and replace it (or the board it's attached to). So I'm tempted to just replace the motherboard as well as what looks like the power supply board and see what happens, but I wanted some of your experienced advice before I spent any money.
    Lots of pictures included. Some are huge, so instead of blowing up the size of this page I made links to most of them.
    http://i.imgur.com/nT9JLti.jpg
    http://i.imgur.com/K4Ld3mp.jpg
    http://i.imgur.com/hZBejiQ.jpg
    http://i.imgur.com/VvIBEBS.jpg
    http://i.imgur.com/LKNWWfL.jpg
    more close-up imaged can be found here: http://caibbor.imgur.com/all/
    Thanks you in advance!
  • heavymachines
    • Mar 2011
    • 1028
    Re: Toshiba 50L1350U - Dual Image/Horizontal Shift After Power Outage
    Nevermind
    • freakaftr8
      • Oct 2012
      • 3743
      Is the picture flickering well you're getting the dual image? This sure does look like panel failure
      • caibbor
        • Mar 2017
        • 5
        The "dual image" kind goes from a normal image back to dual every second or so (sometimes less, sometimes more).
        It's like it wants to go "into focus" but just can't.
        the light doesn't flicker, no. the backlight stays on entirely.
        • freakaftr8
          • Oct 2012
          • 3743
          That's panel failure. Try this take off the metal frame exposing the LCD panel edges and use a heat gun and heat up the edges from top to bottom each side as you're watching the picture period does it straighten out?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Can't help on this but perhaps you can help someone else who has a similar set with a different problem.
            What reading do you have for the voltage driving the leds?
            • caibbor
              • Mar 2017
              • 5
              I took a heatgun to the edges and sides and everything, I didn't notice any difference. I didn't get it TOO hot, but it was a legit heat gun and warmed it up pretty good. What else do you suggest I do?
              Sorry this took so long, but I'd be happy to help. You just want the voltage between the on/off LED? I'm not sure what a "driving led" is.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Someone else was having problems and couldn't decide what the voltage to the panel leds for this set should be. The thought was anyone else with this model doing a search on the forum would have the answer.
                • nomoresonys
                  • 12274
                  • U.S.
                  The storm may have cooked something, I'd try to find a reasonable main board as a start, good luck.
                  • caibbor
                    • Mar 2017
                    • 5
                    After I tried the heat gun trick, I gave up and walked away an left the TV on. I came back to find the TV was no longer displaying anything at all and no backlight. So as it stands, it just doesn't do anything at all.
                    considering replacing the mainboard.
                    • nomoresonys
                      • 12274
                      • U.S.
                      Any progress?
                      • koka0011
                        • Apr 2013
                        • 30
                        • Sri Lanka
                        did you cut ckv lines?
                          09-06-2024, 05:27 AM
                          09-06-2024, 05:59 AM
                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                          09-06-2024, 05:33 AM
