LG 55LD650 weird problem
  • hienton2
    • Sep 2009
    • 183
    My cousin tv LG 55LD650 has problem :It keep on /off 3 times then shutdown
    Tv can not stay on.I upgrade firmware then it is ok .He bring it to his home and
    hook to his cable box hdmi then tv goes wrong again sane problem.I want to
    do upgrade again but tv say it has same version it can not upgrade.I did reset
    eeprom but no fix.Can I make it back to old version. Anybody help to fix this?
  • hienton2
    • Sep 2009
    • 183
    Re: LG 55LD650 weird problem
    I think the eeprom is corrupted again after first update when hook up the box
    • chaos-theory
      Nitro rx580 very weird problem, VCORE and EN
      by chaos-theory
      Hello!
      I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
      All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
      08-17-2024, 04:56 PM
    • c.daniel
      Lenovo V310-15IKB weird bios problem...
      by c.daniel
      Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
      sn LR09493E
      MB DAOLV6MB6F0 REV. F
      The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
      Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
      Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
      08-22-2025, 05:39 AM
    • sorrowfulfloyd
      Samsung UE32J5373AS Weird LED Problem
      by sorrowfulfloyd
      Hi all, first time seeing a LED problem this weird so I wanted to discuss with y'all before handing back this TV to my costumer.
      This TV came to my shop with no picture but sound present. So I thought ok this must be a LED problem and I shine a light with my phone's torch amd and yup I see the image. So I disassemble it and before changing the LEDs I check the motherboard voltages (this unit works with an external 16V DC brick) and I see 54 volts at the input pin of LED strip, considering this TV has 2 strips of 7 LEDs which at 3~ volts it must be equal to like 42 volts. I remove...
      12-23-2022, 07:00 AM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • brockauly
      Macbook M1 A2337 EMC 3598 weird battery charging problem
      by brockauly
      Hi guys,
      If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
      Then if I unplug the charger and plug it back, it won't charge anymore.
      In the first case, main voltage is regulated at ~12.5V and charges the battery.
      After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
      After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
      I found C520A (2.2ยต after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
      02-05-2025, 10:51 AM
