Philips 47pfl6008s unknown caps
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4539
    • Italy - Milan
    Hi, i need to know the values of the electrolytic caps on the secondary side of its power board FSP140-4FS01, at least the ones near the connector to the mainboard, them are 5 one color 1 another color, unfortunately previous technician have put in wrong type of spare parts, 85° general purpose that i think is the reason of the malfunction. Please, i don't know WHAT TO DOOO!!
    (now there are 5 330uF 50V, maximum v-out is 12v so they're overvoltage and maybe undercapacity)
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Philips 47pfl6008s unknown caps
    Leave them they are correct , 50v ok
    • dskall
      • Oct 2016
      • 2905
      • usa
      Don't know the uf of them. 330 may be correct. For smps they recommend 105c low esr caps.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4539
        • Italy - Milan
        forgot about my question i have put 5 - 470uF 25V and it works but i don't know if the problem is solved (not working when cool, then working after some retries, working after hours unplugged, then newly not working by cool)
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Cornito
          Philips 50PUH6400 bad color and gosting / slow motion on one side
          by Cornito
          Hello Team,
          New issue on LCD panel where I need to find out the cause and the potential solution.
          This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
          I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
          When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
          I've checked voltages, no issue found comparing right and left side of the panel driver.
          VHG VGL CKV... are the sames on...
          03-08-2024, 06:41 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
