need repairman 18433 pa
  • ozzy214
    • Nov 2013
    • 319
    • usa
    Anyone good at led repair? I have a beautiful 55" Samsung tv. Im 99.8 sure leds is burned out as no back light. Tv is coming on with sound and think pic with flashlight, but zero back light. LEDS are nowhere to be found online. Similar models are edge lit with a strip left and right side. Im not good at soldering or breaking these down without cracking screen. I kinda want to save it for myself. So what repair shop close to scranton pa that is proficient with stacking repair of leds?
  • Pipolups
    Corsair K70 LUX RGB dying LEDs
    by Pipolups
    Hi there !
    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
    10-08-2024, 11:58 AM
  • THE GTC
    Insignia NS-37D20SNA14 intermittent LEDs
    by THE GTC
    So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
    When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
    11-03-2020, 02:40 AM
  • VitalComputing
    Replacing Mode Indicator LEDs
    by VitalComputing
    I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
    I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
    I thought I could just put a resistor...
    09-17-2023, 04:43 PM
  • jimbofz
    just a quick question do all qled leds appear blue when fault finding ?
    by jimbofz
    i have replaced many leds strips that have changed blue when they are worn
    and the new replacements are perfect white
    but when fault finding do quantum leds always look blue?
    08-28-2024, 06:51 AM
  • Quantum IC
    LEDs for TV Backligth
    by Quantum IC
    Hello everyone
    I'm new to LED strip LED replacement.
    The original LED comes with a single internal LED or chip. I only get at the moment LEDs with two internal LEDs or chips.
    I understand that this is due to the tone of the light they emit.
    My Doubt is:
    Can I use the LED with two internal chips without problem?
    Will there be much difference in the picture?
    I'm going to replace all the LEDs.
    Both LEDs (original and replacement) are 3V and the same size....
    03-04-2022, 04:03 PM
