Samsung ue32f5000 weird issue after led strip repair
  • solidhit
    • Sep 2016
    • Greece
    Hello, I would like to report an issue I have with a Samsung UE32F5000.
    When I received the TV it had no picture. Shining a flashlight on the panel I saw a message on the screen indicating TV was alive but it had no backlight. The power supply was measuring OK so I disassembled the TV and found out two leds were burned on a led strip.
    Since the particular led strip was in bad shape (it had a nasty burn mark near the power connector) I ordered a new strip from ebay and installed it. Now, on this particular set, if you disconnect the motherboard power cable and give power to the set all the leds will light and they did! Confident my problem was solved I reinstalled the panel and decided to give it a final test before putting it all together.
    Well, now my leds light up, the motherboard boots fine (5 flashes then off), it obeys the remote as expected but I have no picture whatsoever!!! I tested my tcon fuse and I measured 12.8v at either side, I reinstalled all cables that connect the various boards as well as the ones that connect the panel to the tcon but the problem remains...
    At this point I have no idea what is happening, I inspected the panel itself and its various cables and I see nothing weird. Any advice would be greatly appreciated...
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung ue32f5000 weird issue after led strip repair
    Check you have not re-installed the panel the wrong way round.
    • solidhit
      • Sep 2016
      • Greece
      Ehh, what do you know!
      Thanks, and I would appreciate if we kept this between us...
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Done it myself when in a rush.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Originally posted by solidhit
          ehh, what do you know!
          Thanks, and i would appreciate if we kept this between us...
          +1
          • Kjell
            Samsung Series 9 - BIOS issue
            by Kjell
            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
            08-01-2025, 09:15 AM
            09-07-2024, 05:50 AM
          • Nairolf
            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
            by Nairolf
            I have a Samsung DM32D display.
            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
            Here’s what I have tried so far:
            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
            From these tests, I suspect the problem might be on the mainboard. Could anyone...
            08-24-2025, 03:47 AM
          • vincentedel
            Samsung SyncMaster 740n Phase Control Issue
            by vincentedel
            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
            04-22-2025, 12:33 AM
          • Manucsl
            QE65Q800TATXXC Samsung TV Issue
            by Manucsl
            Hello.
            My TV is a QE65Q800TATXXC Samsung TV.
            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
            Any ideas to check would be very appreciated 😊
            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
            02-19-2025, 07:47 AM
