Another 'sound, no picture' query. Tosh Regza 32XV555D
  • tyler_d
    • Jan 2017
    After a period off, the TV system turns on and operates normally for between 15 minutes and two hours. The picture goes off and is not visible with a torch in a darkened room, but the set continues to operate normally otherwise.
    I've examined the component side of the power, system and CCF ht boards for visible problems, with no issues visible.
    The system is 6-7 years old I think.
    What is the next step?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Another 'sound, no picture' query. Tosh Regza 32XV555D
    Can you post some photo's of the circuit boards.
    When you lose the picture can you see the backlights with the back off the set?
    Have you measured any of the voltages on the power supply?
    • tyler_d
      • Jan 2017
      I'll measure the voltages from the PSU before and after the screen goes off. Then take out the boards and photograph them in daylight. The backlight is definitely off after the picture goes off.
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • jord4231
        Toshiba 37AV500A Regza TV good power supply no sound no picture
        by jord4231
        Hi Everyone,
        I'm working on a Toshiba 37AV500A Regza TV.
        The issue:
        TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
        The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
        I checked the PSU voltages and everything looked good.
        No bulging caps or signs of heat.
        24v aud = 24.41v
        12v = 11.98v
        5v = 5.062
        p_o/f = Goes high...
        03-29-2022, 09:21 PM
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
      • jchang
        Samsung UN70NU6900F no picture and no sound
        by jchang
        Hi all
        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
        Symptom:
        No picture no sound.
        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
        No sound at all.
        What I tried:
        1. I tried unplugging the left or right ribbon...
        01-09-2023, 06:28 PM
