Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Originally posted by lotas View Post
    How are you going to program someone else's dump of your flash, do you have a programmer? If there is, read the contents of your flash and post it here.
    If it does not go into operating mode, then most likely your firmware is damaged, you read the contents (dump) of your 25Q16BSIG and show it to me, I will restore it and it will be operational and then you will download my corrected dump and your TV will work again, when provided that the problem is in the firmware.
    Thanks Lotas. I have been doing ecectronics repairs for a long time, but this is the first time that I need to do a firmware load. I will look into getting a porgrammer. I was hoping that with a USB drive I could just load new firmware. Like I said, this is my first time.
      On this chassis you will not be able to download the firmware via USB, you will not even have access to USB, just update it if the TV is fully working, and only through the programmer.
        hi every one i need dump of Thoshiba Toshiba 40bv700f part number 17mb61-2
          please dump tv IBEROSTAR 32 (Main Board): T.MSD 309.6B 10426 PANEL LC320WUF
          THANKS
            THANKS
            Post your non-working dump here and I'll try to fix it.
              post your non-working dump here and i'll try to fix it.
              thanks my fr
                thanks my fr
                Your dump soft works, try with a clean nvm.
                After turning on the power, do not press any buttons for 20 seconds.
                  your dump soft works, try with a clean nvm.
                  very thanks work perfect
                    Ok!
                      Good!
                        Originally posted by promo7uk View Post
                        as a member of this top notch site which over the years has helped me out alot. i want to give back.. so ive uplloaded a shed load of files to one of my servers enjoy,! and if you require any new JVC tv firmware. i have lots more, please ask,. what software / firmware or files you are after you never know as a tech i might have it cheers ..
                        PLEASE SAY THANKS,
                        http://77.81.110.132/Firmware/As36dFeRcVgFdd7g23JkLbX/
                        DONT MISSTREAT MY SERVER PLEASE.
                        Dear Promo7uk,
                        I tried to look on your server link which you posted in the eprom dump sticky but it does not work for me.
                        I posted a request https://www.badcaps.net/forum/showth...35#post1279035 but have not heard back yet.
                        I was hoping you may be able to assist with software or firmware which may fix the issue on my JVC LT-55C870.
                        Thanks in advance
                        Regards
                        Russell
                          Originally posted by Russ17 View Post
                          Dear Promo7uk,
                          Thanks in advance
                          Regards
                          Russell
                          Unfortunately this member I have tried contacting before without getting any reply from using the PM (Private Messaging). So I think it unlikely that you will get a response from them either.
                          Good luck with sorting your TV out.
                            Please dump tv Samsung UA50TU7000k
                            IC 301 : W25Q40B
                            Board BN96-50987C
                            Thankyou so much!
                              JVC lt32vf52k
                              17MB110P
                              VES315UNDA-2D-N11
                              Continious led blink
                              25l1606E dump please
                                Originally posted by cristiannec View Post
                                JVC lt32vf52k
                                17MB110P
                                VES315UNDA-2D-N11
                                found one that works.
                                thanks
                                  Anyone got the eeprom dump for mainboard 40-nt67ES-mac4hg?
                                    hello
                                    i need dump for vivax TV-32LE73
                                    TP.SIS231.PT851
                                    tv shuts on off, i found dump but picture is upside down, and there is not in service menu mirror or other option to turn it
                                    - damaged
                                    - upside down
                                      Originally posted by dinche_ze View Post
                                      hello
                                      TP.SIS231.PT851
                                      - damaged
                                      - upside down
                                      You also need to write down the panel number.
                                        broj ploce je TP.SIS231.PT851
                                          I understood that the motherboard number is TP.SIS231.PT851, and what is the panel (matrix) number???
