LG 37LC5DC - 'snow' for video/audio but no control of buttons/menu/etc...
  • neex
    • Jan 2017
    • 27
    All voltages to my knowledge check out fine. The set comes on and I am unable to power it off with the power button.. volume control doesn't work and neither do source selections.... I only get fuzz and 'white noise' audio. I didn't know if this was something common - I have searched the forum so I apologize if I missed something... I will be replacing every primary/filter cap but something tells me this isn't the issue as the rails seem to be putting out voltage within/above spec....
    Here are my readings from P201 and P202
    202
    (1)19V - 20.6
    (2)19V - 20.6
    (3) GND
    (4) GND
    (5) 6V - 6.09
    (7) GND
    (8) 3.4V - 3.46
    (9) GND
    (10) 12V - 12.8
    (11) GND
    P201
    (1) 3.4V (1.94 with connector unplugged and 3.46 with it plugged in)
    (2) GND
    (3) 6V - 5.96
    (4) DIM -
    (5) GND
    (6) ST/5V - 4.97
    (7) I.B. - 1.69
    (8) ERR - .013
    (9) IC - 4.8
    (10) GND
    (11) ST/5V - 4.96
    (12) ON - 2.69
    (13) ACD - 4.21
    measuring from one side of the ground plane to the ground screws is pretty consistent at .036V...
    Any ideas? I feel like I'm pretty close here....
    Thank you,
    A.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG 37LC5DC - 'snow' for video/audio but no control of buttons/menu/etc...
    I would be checking for voltages at the regulators on main board
    • dskall
      • Oct 2016
      • 2905
      • usa
      Also check for voltage at cable to the buttons. There should be power there and one or more pins should change voltage when you press different buttons.
      • neex
        • Jan 2017
        • 27
        I pulled it on the bench again and the original statement about 3.4 changing states was false. The 3.4 ON pin reads 1.8V even when powered with backlights on. I did check the pinout from the power button and it changed voltage from 1.94V. All I can think of now is that a regulator somewhere on the main board is outputting the same or very close. I've also been probing transistors to see if any of them pass along the button press.
        I think that once the 3.4V rail is sorted out this should be fixed. Time to check the backside of the main board I guess....
        P1300 shows 3.3 high to 2.17 at KEY2 when power button is pressed. The very first cap to the right of the circuit tests as open. I hope I'm getting close... now to find a 8b 47 25J compatible cap in by parts bin....
        How do I interpret this capacitor? I found B to mean +/- 0.1pF and I can guess the 25 represents voltage? Is this a 470uf @ 25V cap? Anyone??
        Thanks!
        Last edited by neex; 04-08-2017, 06:25 PM. Reason: need help interpreting SMD v type capacitor coding....
        • neex
          • Jan 2017
          • 27
          Does 47nF sound right? @5% Tolerance? Not sure of the voltage though... guess I'll aim high...
          • neex
            • Jan 2017
            • 27
            nevermind - figured out the cap after testing a good one out of circuit... only problem left is no RL ON being sent from mainboard... I think I checked every regulator but might have missed one... getting very close....
            • dskall
              • Oct 2016
              • 2905
              • usa
              If your getting voltage changes from key press you may have an eeprom problem.
              • neex
                • Jan 2017
                • 27
                that would be more interesting than I bargained for.... the key presses don't manifest any voltage fluctuation at the SMPS however.... only on the lower section of the main board by KEY2 outputs...
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Key presses go through the main processor.
                  • neex
                    • Jan 2017
                    • 27
                    maybe I'll get a scope on the outputs on the processor then... thanks.
                      LCD LED TV Service Menu Codes
                      TCL LED TV Service Menu Code
                      LG LED TV Service Menu Code
                      10-31-2024, 03:58 AM
                      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                      09-12-2024, 02:00 PM
                    • JaquesPratt
                      Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                      by JaquesPratt
                      I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                      This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                      07-16-2024, 01:04 AM
                    • bohaboha
                      Use different IR SENSOR /TV CONTROL BUTTONS BOARD Possible
                      by bohaboha
                      Hi everyone is it possible to change or use a different IR SENSOR / CONTROL BUTTONS BOARD on a tv?
                      exp: from a Philips to a Samsung or any
                      if it breaks or if there is some odd brand or if universal remote control would not work
                      05-05-2023, 07:24 AM
                      GeForce RTX2080 Super Aero video gaming card issues help need
                      This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                      Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                      05-07-2023, 08:12 AM
