Samsung PS-50C91HD - disconnecting boards
  • Tuned
    • Jan 2017
    • 11
    Samsung PS-50C91HD - How do I disconnect white ribbon connector from Y-Sustain Board and how do I disconnect Y-Sustain Board from two Y-Buffer Boards?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung PS-50C91HD - disconnecting boards
    Connector latches and screws.
    • Tuned
      • Jan 2017
      • 11
      Connector latches and screws I can see. Screws I can unscrew. Latches I do not want to break. How do I unlatch the connectors?
      • Tuned
        • Jan 2017
        • 11
        Anybody with advice on how to unlatch and not break the connectors?
        • petehall347
          • Jan 2015
          • 4451
          • United Kingdom
          post some pictures .
          • Tuned
            • Jan 2017
            • 11
            Please see photos. Black connector y-sustain to y-buffer and white connector (data ribbon).
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Its not hard, will link one of my vids on this chassis. We cant help with everything and wipe your ass the whole time you have to try it yourself. Hopefully this can help watch it all the way through.
              https://youtu.be/57aDWsiLIxE
              • Tuned
                • Jan 2017
                • 11
                Thanks very much ReeceyBurger123. The video is great. Now I know how to do it without breaking anything. But now I have a new problem - which hand must I use for the wiping? :-)
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Lol I like being a twat sometimes have fun, keep us updated and the same hand you write with
                  • Tuned
                    • Jan 2017
                    • 11
                    Thanks again ReecyBurger 123. I also have a Samsung PS50P91FD that was not working (click of death) when I got it. I replaced two capacitors (blown) in the power supply and it works very well now (will see for how long). So my questions are - what else should I look out for now that I have the back off it - and should I add cooling fans (if so what and where)? When I do not try to fix broken TVs I try to fix my Land Rovers (all three broken ones) - so you see there is no hope for me! And being down under in the colony makes it worse!
                    • petehall347
                      • Jan 2015
                      • 4451
                      • United Kingdom
                      left hand of course ..that is why folk shake hands with their right hand
                      • Tuned
                        • Jan 2017
                        • 11
                        Thanks petehall347 - but now you have me worried again - what about the people who grab your hand in both of theirs? I am all anxious now and need to watch some TV.
                        • petehall347
                          • Jan 2015
                          • 4451
                          • United Kingdom
                          this is why b days were invented . you get to wash your hands at the same time ...
                          • Tuned
                            • Jan 2017
                            • 11
                            Just a quick report - all went well. Broke nothing and resoldered all the joints of components mounted to heat sinks on Y-Sustain Board. All good now. Does not lose video when hot. I am thinking of modifying the back cover so that I can use it as a toaster - the heat sinks get hot enough! :-)
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              thanks for the update this seems like its is a common issue we see on these samsung s with the soldering issues on the parts on the heatsinks.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Add fans and you better heatsink them buffer ICs and recap the ymain and tighten all screws on the ymain and xmain and recap the xmain and recap the psu and then your done
                                  09-07-2024, 05:50 AM
                                • Yanleb
                                  Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                  by Yanleb
                                  Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                  If they are not compatible why did Samsung give them the same part number to begin with?
                                  08-04-2025, 11:35 PM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
