TC-P58VT25 no display
  • gdawg
    • Sep 2012
    • 170
    Hi all. I haven't been on for awhile but I need some help on a Tc-P58vt25.
    I was on an old thread and had to back burner this set.
    This went from 7 blinks, blowing up-then to 10 bliinks and blowing up.
    I got it to 6 blinks and not blowing up. I reviewed the previous post and tw 2005 said to check Q551 which I did and was not shorted.
    It apparently was open,cause I replaced it and the SS and SC leds stay on and no codes.
    However, no display. I checked VSCN voltage and only show -47 volts and I know it should be about -190 if I recall.
    I do have 207.8 volts going in. Any ideas. I thought maybe I lost a driver but dont know theory that well. Any ideas would be great. I feel like I am so close.
    This is the tnpa5175 SC board
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: TC-P58VT25 no display
    Remove buffer from the Tv completely jump SC50 on SC board does Vsc come up ?
    • gdawg
      • Sep 2012
      • 170
      Thanks, I will try that tonight when I get off work. I thought about trying that, I guess i didn't because the buffers checked good.
      • gdawg
        • Sep 2012
        • 170
        Well my results were different but in the wrong way. I still have the 207.8 at the power going into the SC board. With buffers totally disconnected and sc50 jumped,
        I have -37.4 volts. I am checking at the resistor marked TPVSCN. I checked Vad and have -187.1 at that test point,
        No codes, and led's on both boards bright. I can hear the SC board with the usual hum when it turns on.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Sc is faulty still then.
          • gdawg
            • Sep 2012
            • 170
            I guess I will have to look closer at the schematic to follow it thru.
            I know when I replaced the Q16551 I got rid of the 6 blink code. It looks like IC16521 is in the same circuit.
            I did replace it on the original rebuild, thought maybe I should replace it again.
            Also saw a VSCN generator IC. Anybody have any ideas which area I should be looking at.
            I have replaced a ton of parts on this board as most of the TNPA5175 boards.
            Any help is appreciated.
