PANASONIC TX-L32D28 - Blown fuses
  • jondoe
    • Nov 2016
    • 547
    I have a new toy to tinker with, this time it's a PANASONIC TX-L32D28. The power board has blow both it's fuses, while poking around I tried to desolder one of the relays and broke it in the process , it's a DEC I can't find an equivalent of, so I ordered one from China on ebay, it's a DQ1U 12VDC DEC, if anyone is familiar? I think a HF36F012HST would cover it as a temp solution.
    Any hoot, here's the board, no sign of bulging caps, no sign of anything burnt out, the two rectifiers on the hot side both check out OK Any ideas?
    Thanks.
  • jondoe
    • Nov 2016
    • 547
    Re: PANASONIC TX-L32D28 - Blown fuses
    Thanks to some lovely Russians I've found some circuit for the N0AE4JJ00015 power supply! Attached for others to find
    • jondoe
      • Nov 2016
      • 547
      This tv is actually a TX-L37D28, but hey ho, I can't edit the title now
      Further testing today revealed D210 and D211 to be faulty (bottom right, just above the floating transformer). They are marked "JE 1G5" - Google hasn't really helped with identifying those, anyone have an idea what they are?
      The 1G5 rating does pop up on some diodes, but I can't find what the original is :/
      • jondoe
        • Nov 2016
        • 547
        I've found what appears to be another dead Diode (PCB has a diode symbol), this ones large and has a blue ring, T2D 04 I don't know if it's a Zener or not :/ Fails a Diode test, 0L in both directions, 1.6 mOhm, 0.9 mOhm in the other.
        It looks near identical to these
        • jondoe
          • Nov 2016
          • 547
          This would be the weird diode I couldn't test, no wonder my meter didn't know what to do with it, that looks like two types of diodes in one package
          • jondoe
            • Nov 2016
            • 547
            Replaced D210 and D211 with a guess on the diode rating, seeing 6V at the P1 connector and no blown fuse. However, I'm waiting for the 12V relay to arrive, so fired it up without it.
            If it doesn't pop after I've replaced that relay, I'll stick it in the TV and fire it up and see if it goes bang.
            • jondoe
              • Nov 2016
              • 547
              Well, my relay arrived and my physical dimensions were off, they don't fit in the board So there would be no 12v rail being turned on anytime soon.
              I thought I'd put the board back in the TV and at least see if I got a standby light seeing as I had 6 volts on the 5.8v standby rail, however, there was a loud pop and now there's nothing, she's dead. More fool me.
              There was a noticeable arch of electricity from Q202, the casing is a little scorched between drain and source pins, I pulled it but oddly enough it still tests fine on my component tester.
              I seem to be getting 2.5volts on pin 12, which is the SOS and -3volts on the Relay pin.
              I'd be grateful for an experts opinion, schematic attached
              • jondoe
                • Nov 2016
                • 547
                I've now found an odd 3 legged thermal resistor combo, which doesn't seem to be very well at all, it's RWT05 15ΩJ, (R003 on schematic). Although this has three legs, only two of them are in circuit, 1 leg is soldered in, but there are no tracks to it on the PCB (image attached) I suspect this is a test point of some kind?
                I assume I can replace with a two legged alternative?
                • jondoe
                  • Nov 2016
                  • 547
                  Have ordered a straight 5w 15ohn resistor, as far as I can tell this should be fine, it will just lack the thermal fuse, not as safe, but will allow the circuit to operate.
                  HF36F012HST was NOT a suitable replacement for the relay, so waiting on a couple of 2nd hand ones from China *gulp*
                  You ever get the feeling you're talking to yourself?
                  • jondoe
                    • Nov 2016
                    • 547
                    Replaced power resistor, replaced relay. mosfet still shorting out, although testing OK off the board. Fault clearly elsewhere, but beyond my low skills.
                    Replaced entire power supply board with second hand later revision (less parts) TV is now working fine.
                    Happy new year.
                      Surface Mount Fuses Fundamentals Datasheet
                      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                      10-07-2024, 06:07 AM
                    • MrzPdlch
                      Blown fuses on Gigabyte GTX 980TI 6GB
                      by MrzPdlch
                      Hey everyone,
                      I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                      Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                      Find some pictures of the actual GPU together with a picture of how it should look like.
                      I also wonder whther it might be a problem that there...
                      03-10-2024, 04:14 PM
                    • BMCappelletti
                      Sonos Play 1 with blown cap and fuses
                      by BMCappelletti
                      Hi there.
                      I was given a Sonos Play 1 (yeah, very old) that does not turn on.
                      Checking the main board, I can see a blown cap, that connects to two blown fuses. Right by the LAN port.
                      Where should I start looking for the main fault?
                      Thank you....
                      08-10-2023, 04:02 PM
                    • gozotto
                      Sharp LC-40LE812E fuses blown
                      by gozotto
                      I repaired a Sharp LC-40LE812E TV with the main power board DPS-126CP B.
                      All fuses blown and the capacitor C7813 (220pF 1KV) was cracked. After replacing both, the TV works again without any problems. After 2 weeks the same problem apears with the same symptoms. What can the C7813 blown again and again? The schematic can be found here.
                      Thanks in Advance
                      gozotto
                      04-04-2022, 12:14 PM
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                      11-20-2024, 08:52 PM
