Need datasheet IC BM81202 ,SONY LCD TV
  • rawan
    • Oct 2009
    • 57
    Hi
    I Need datasheet IC BM81202 ,SONY LCD TV,
    used in panel Y320AN03S4L
    Mac
  • iglitare
    Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
    by iglitare
    i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
    Backlight seems to work, Sound (Setup menu after reset) works.
    If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
    Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
    With my small knowledge i would think at least the cables are good.
    Can this happen because of a bad tcon board?
    Or is it always a bad/shorted...
    09-04-2025, 07:13 AM
  • rimwall
    Sony KD-65x7500D - double image - Tcon or Panel?
    by rimwall
    This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
    I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
    Today, 02:09 AM
  • r3vsEngIT
    Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
    by r3vsEngIT
    65x900h with the panel from a 65x930d.
    900H: model yr 2020, Samsung panel
    930D: model yr 2016, Innolux panel
    spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
    the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
    07-11-2023, 11:11 AM
  • guidodroid
    Bad Panel in Sony Bravia X850G
    by guidodroid
    Hello all,
    I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
    It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
    Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
    The issue is not as bad as others that I've seen around, but is indeed noticeable...
    03-19-2022, 12:08 PM
  • PlanB
    Sony KDL-55W828B Hotspot in LCD panel
    by PlanB
    Hello everybody,
    I need your expertise if my asumption about the failure of this TV is correct.
    A Sony KDL-55W828B only shows vertical red stripes that vanish to the top when switched on.
    When only the right side of the LCD is plugged into the T-CON board the right side shows a good image, while the left side is white.
    When only the left side of the LCD is plugged into the T-CON board the LCD shows a complete white image.
    I checked some signals on the T-CON board but was not able to find something strange. Then I checked the the caps...
    02-05-2022, 09:46 AM
