Alibaba LCD Panel??
  • realdealthill
    • Nov 2016
    • 53
    Alibaba LCD Panel??
    Does anyone have experience ordering LCD panels from them?
    I heard they cant use brand names for there panels, so how do you know if they are compatible with your tv????
  • NolesFan
    Can LED panels be used from different TV's ( or the internals to the panel )?
    by NolesFan
    I have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you
    06-23-2025, 09:19 AM
  • triplefour
    SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
    by triplefour
    TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
    tcon is built into mainboard.
    Only one cable goes to panel boards.
    there is a cable from one panel board to the other that links them.
    cost cutting measure that results in us having harder time to diagnose.
    removing the link to the second panel board allows TV to stay on with stable backlight but no image.
    used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
    07-28-2022, 07:59 PM
  • Storyteller12
    QN55Q60R Service Menu Panel Help
    by Storyteller12
    I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
    I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
    I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
    the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
    01-13-2024, 01:57 PM
  • maneatingmonkey
    Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
    by maneatingmonkey
    I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
    There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
    03-27-2024, 07:17 AM
  • KYBOSH
    Samsung UN50TU8000 - Dead Panel Forensic Questions
    by KYBOSH
    I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
    When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
    When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
    Later I checked for shorts on the panel PCB boards but could not find anything.
    When I took a look with the FLIR i noticed the 2 resistors...
    08-10-2024, 08:39 AM
