LG 60PV450 EBT vs EAX number?
  • daneyuleb
    • Jul 2014
    • 21
    I'm confused about the versions of the Main boards for a LG 60PV450 60 inch plasma. Can one assume if the EAX number is the same, the EBT number will work to replace a main board with a different EBT number?
    This one's numbers are:
    EAX63728604(4)
    EBT61663001
    I'm seeing EBAY sellers with boards from the same tv (60pv450) with the same EAX number... but different (or unspecified) EBT numbers and wondering if they will work...?
    Just wondering if anyone has experience here?
  • bruce35
    HP 600 G3 MT serial number change please
    by bruce35
    HP 600 G3 MT
    SERIAL NUMBER MXL8301K1C Serial number in the file in bios
    SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
    Thank you very much...
    09-24-2025, 02:32 AM
  • sikocan
    Lenovo X1 Carbon 9th Gen Black Screen
    by sikocan
    I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
    SN: PF3G1REP
    MODEL: 20KW-00J1AU
    PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
    Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
    06-24-2025, 09:01 PM
  • piernov
    Beginner's guidelines
    by piernov
    You have a laptop that does not power on, powers on but shows no image, crashes, etc… You want to fix it but you don't know where to start.
    There are 2 situations:
    1. You just want your laptop fixed
    2. You want to learn about fixing laptops
    Sorry, but if you're in situation number 1, we recommend you to use the services of a trustworthy professional repair shop.
    Unfortunately, if you're not serious about learning, you will waste your time and money, and you will make us waste our time as well.
    If you are in situation number 2, then please continue and...
    09-20-2020, 09:46 AM
  • acerRI
    Gigabyte MB missing serial number in BIOS
    by acerRI
    We have in company to custom PCs with Gigabyte B760 GAMING X (1.0). When i export hwhash for enrolling PC in azure, i got computer name as MMDEFAULTSTRING.
    PCs wiht this name are not compliant with company policy, number should be MMDxxxxxx (xxxxxx is serial number of mb).
    I have found that is possible to embbed in BIOS serial number so when i exporting, it will get proper computer name.
    Does anyone have know if somehow do that, maybe with some hexeditor, because i have found that some specialized tools are needed.
    Any help will be...
    09-23-2025, 05:26 AM
