Samsung UE32C6510 Red LED flashing not powering on.
  • lesnajair
    • May 2015
    • 57
    • United Kingdom
    Hi all.
    Looking for help on the Samsung above please. A friend said that he tried to update the firmware over air, onscreen notification said tv would turn off and then back on after 3 seconds. It didn't turn back on and now the front red led flashes slowly and TV makes a clicking noise. I've taken the rear cover off and nothing appears to be blown or burnt out! Possible corrupt firmware or incomplete download maybe? Hope this info helps?
    Thanks for any advice.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Samsung UE32C6510 Red LED flashing not powering on.
    I would try a reflash. Follow the instructions as given on Samsungs site.
    http://www.samsung.com/uk/support/model/UE32C6510UWXTK
    • lesnajair
      • May 2015
      • 57
      • United Kingdom
      Thanks for your fast reply Dick Barton! Will that work even though the set wont power on?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Nothing lost in trying. Read the instructions given in the pdf file and fingers crossed.
        • lesnajair
          • May 2015
          • 57
          • United Kingdom
          Hmmm, tried the firmware option by USB but its not working. Any ideas where to go next? Is there a way to force read the USB stick, as I don't think it was read on startup? Oh, there wasn't a pdf doc included...
            09-07-2024, 05:50 AM
          • H34TO
            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
            by H34TO
            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
            06-17-2025, 07:17 AM
          • GeckoGreen
            Samsung service bulletin: need firmware file for PN63C550 TV
            by GeckoGreen
            I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
            You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
            The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
            Will you please help me get the [2D63]LOGIC.bin file for my TV?
            05-17-2025, 02:47 PM
          • Mirenia
            Samsung UEMU6199U - no Standby - bad Firmware?
            by Mirenia
            I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
            Voltages on the power supply board is okay. Backlight test is also okay.
            I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
            So I think my TV has exactly this issue.
            Can someone please fix the dump?
            And how do you do that?
            As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
            05-12-2025, 06:13 AM
            09-06-2024, 11:40 PM
