Digihome PVR80 (UK)
  • linker3000
    • Sep 2007
    • 24
    Digihome PVR80 (UK)
    Hi Everyone, just to let you know that I have just recapped the PSU board in a Digihome PVR80 Digital Video Recorder. In the UK, this unit is (was?) sold under quite a few other brand names and, for aficionados, my unit has the T810 hardware.
    The unit is a ' customer return' (label on bottom says 'Argos') bought from a dealer on ebay (so no warranty) and had worked fine for about a year or so, but when I looked at it the other day the front matrix display was showing corrupt text. I powered down for about 30 secs but when I switched on again some of the display segments glowed very faint and the system did not boot.
    Checking the innards, I instantly saw a domed-top capacitor on the PSU board and so I came here to check the make: G-Luxon - uh oh! I took the plunge and changed all the electrolytics on this board and the unit is working fine again.
    The main logic/tuner board also has a *lot* of G-Luxon caps but I don't really fancy tackling that one unless I really need to - hopefully they are under less stress than the PSU ones and so will behave for a few years longer.
    Some good pics of the innards on this site (nothing to do with me) for the curious:
    http://www.vwlowen.co.uk/vestel/digihome.htm
    Cheers
    L3K
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • sfernandes
    Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
    by sfernandes
    Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
    What I have done to try to isolate the issue so far:
    The system powers on and stays on with...
    01-23-2023, 06:03 PM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
