Blaupunkt TV 40/122I-GB-5B-FHBKU
  • Slang
    • Oct 2006
    • 49
    Hi
    i need the eeprom/flash dump for this TV with Samsung panel.
    TV codes:
    ref: B40A122TCFHD
    prod. code: BW40Z122BFBKUE567
    Thank you in advance
    Slang
  • SidneyCanadas
    93C46 and 93C56 EEPROM
    by SidneyCanadas
    I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
    https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
    Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
    06-14-2023, 01:16 PM
  • dmccul2698
    Pioneer DEX-P99rs "No EEProm " diagnostic code.
    by dmccul2698
    Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
    1). Understand the schematic and check the connections between the EEProm and DSP
    2). Check the functionality of the EEProm
    I don't know if this is the unit's problem but it's a place to start.
    I have little to no electronic experience...
    04-08-2024, 05:32 PM
  • edgarmg15
    Damaged EEPROM on TV Vizio E320-A0
    by edgarmg15
    Hi everyone
    I´m trying to repair a TV Vizio E320-A0 that I found in the street
    The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
    The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
    So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
    11-19-2022, 03:46 PM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • AlexGsmMaster
    Eizo CS2740 eeprom dump, search.
    by AlexGsmMaster
    Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
    07-26-2025, 03:24 PM
