vizio e371vl Won't turn on
  • geshtu
    • Sep 2016
    • 8
    • usa
    I have a vizio e371vl TV that won't turn on. It doesn't have a logo light go amber or backlight at all.
    The power board has 5V standby power. The fuses seem OK on the control board and power board and I can see the 5v on the control board. Is there anything else I can try? The caps seem ok, visually.
    I am new to this and am trying to learn. I greatly appreciate any help!
    http://imgur.com/a/Nud3q
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: vizio e371vl Won't turn on
    Check the PSon and BLon pins on the PSU and try to turn the TV on. THe maybe labeled just as on/off etc.
    • geshtu
      • Sep 2016
      • 8
      • usa
      the 12v line os 0v, the on/off line is alwas 0v when trying to press the power button. Same with the YBR_0 and Status lines
      • geshtu
        • Sep 2016
        • 8
        • usa
        I might have found the issue. There is a DC to DC converter that has 5v input and 5v on the enable, but the output is 0.13 volts. The other side of the inductor also only reads 0.11 volts. I measured between that and ground and am reading a near short. Am I on the right track? I will try to hunt down where the short might be.
        http://imgur.com/gallery/P5X3A
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          I figured that you have a main board problem. You are right on track, checking these regulators and buck converters. Vizio has a problem with those. It doesn't have to be a short on the LDO's... it just wont output the right voltage.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • Yanleb
            LG 60PK550 Logic Control Board EBR63450301
            by Yanleb
            Hi all, I just want to share the repair of my 60PK550-UA TV set.
            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
            C57: 3.30V
            C61:...
            07-20-2023, 12:38 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
            Linear Garage Door Opener Control board took a crap install a new control board back normal
            I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
            02-08-2025, 06:52 AM
          • brzostos
            HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
            by brzostos
            Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
            After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
            Original HP 150W power supply, the diode in the power socket lights...
            10-01-2024, 01:34 AM
