samsung PS42A410C1 turns on and off
  • joe-joe
    • Aug 2016
    • 37
    • België
    Re: samsung PS42A410C1 turns on and off
    what i can reed on ic 3007=A215C Q835
    i will do the test with the power supply next week!
    i let you know!!!
    thanks!!
    • joe-joe
      • Aug 2016
      • 37
      • België
      the powersupply is working fine when i do the test with the resistor
      so i think i can exclude the powersupply!!!!
      • flocko
        • Nov 2012
        • 1121
        time to run the sets logic board test patterns without the main board connected if these run Ok, then it points to a defective Main board confirming you first thoughts in post one
        • joe-joe
          • Aug 2016
          • 37
          • België
          how can you let it run without the main board connected??????
          • flocko
            • Nov 2012
            • 1121
            you need to start looking though our search feature for the answers to your problems,you will find it a lot faster than waiting for a reply,search for Samsung logic board test patterns, read then test
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              This may help you too
              https://www.badcaps.net/forum/showth...+test+patterns
              • reinforce
                • Mar 2013
                • 10
                • Austria
                #27
                Hi everyone!
                Just wanna know if there is any progress in this repair thread.
                I am having the same problem just like joe joe. PSU unit BN44-00204A is tested
                ok. All voltages remain constant when PS_ON and / or VS_ON enabled.
                I suspect the culprit lies on the Main Board BN41-00982B. Unfortunately, I haven't found schematics for this mainboard. Does anyone know replacing the eeprom will solve the turning on and off problem?
                Thanks in advance for any help!
                  09-07-2024, 05:50 AM
                • Egidio85
                  Samsung UE55F8000SZ Turns on and off immediately
                  by Egidio85
                  good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                  This defect happens continuously, hearing the classic click of the relay every time.
                  Power supply board BN44-00636B
                  disconnecting the mains and lamps from the power board always causes the same problem.
                  Is it normal that without anything connected this power supply turns on and off cyclically?
                  any suggestions on what to check?
                  thanks in advance
                  03-11-2025, 12:45 PM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
