Samsung LN46E550F6FXZA no backlight
  • Mr. Volt
    • May 2016
    When plugged in but turned off, the TV has a red led lit.
    When turned on you get the boot up tones and TV audio. The red LED blinks 5 times and goes out.
    There is no picture. However, performing the flashlight test shows the picture so I believe the backlight is not working.
    I can find no burned or damaged components on any of the four boards. Also I cannot find any puffy capacitors.
    Using the diode checker on my meter, I checked the diodes, bridge rectifier and some of the transistors on the power board and they all seem good.
    There is 170VDC on the 82uF 450V capacitor when the unit is plugged in but off.
    The voltage drops down to 166VDC when the TV is turned on.
    When turned on I measured the following voltages going to the Inverter board:
    12 LD 0.08VDC
    11 13V 12.7V
    10 CNT_PRT 12.7VDC
    9 OVP 0VDC
    8 GND GND
    3 Low 0VDC / 0VAC
    1 High 0VDC / 0VAC
    BackLight Inverter Board
    K$27-D056264-L$ABX213S063601D
    Samsung 27-D056264 (T87I154-00) Backlight Inverter
    Power Board
    146F1_BHS
    BN44-00441A
    Rev 1.2
    Date: 11.03.15
    I am capable of soldering most components and measuring voltages.
    I thought I read somewhere you can disconnect the the main board to test the backlight but I
    have not tried that because I was not sure if that was ok to do.
    Are there any steps you can suggest to narrow down the fault?
    Thank you in advance for your help.
    09-07-2024, 05:50 AM
  • C152Heavy
    by C152Heavy
    Summary for TL-DR readers:
    • VCC pin (18) of PFC...
    01-11-2023, 02:53 PM
  • sansanpartida
    Samsung QE82Q70RAT no backlight
    by sansanpartida
    Hi everyone!
    Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
    My issue: No backlight.
    Model: QE82Q70RAT
    Type No: QE82Q70RAT
    The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
    So hopefully, I can fix this cheaper.
    05-22-2024, 06:56 AM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
  • Warrensmith
    Samsung BN44-00807E Low Backlight
    by Warrensmith
    Symptom is dim backlight - this set came in with almost no backlight.
    Samsung UN55JU6500FX2A
    1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
    2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
    Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
    10-27-2022, 07:09 AM
