Samsung LN46E550F6FXZA no backlight
  • Mr. Volt
    • May 2016
    When plugged in but turned off, the TV has a red led lit.
    When turned on you get the boot up tones and TV audio. The red LED blinks 5 times and goes out.
    There is no picture. However, performing the flashlight test shows the picture so I believe the backlight is not working.
    I can find no burned or damaged components on any of the four boards. Also I cannot find any puffy capacitors.
    Using the diode checker on my meter, I checked the diodes, bridge rectifier and some of the transistors on the power board and they all seem good.
    There is 170VDC on the 82uF 450V capacitor when the unit is plugged in but off.
    The voltage drops down to 166VDC when the TV is turned on.
    When turned on I measured the following voltages going to the Inverter board:
    12 LD 0.08VDC
    11 13V 12.7V
    10 CNT_PRT 12.7VDC
    9 OVP 0VDC
    8 GND GND
    3 Low 0VDC / 0VAC
    1 High 0VDC / 0VAC
    BackLight Inverter Board
    K$27-D056264-L$ABX213S063601D
    Samsung 27-D056264 (T87I154-00) Backlight Inverter
    Power Board
    146F1_BHS
    BN44-00441A
    Rev 1.2
    Date: 11.03.15
    I am capable of soldering most components and measuring voltages.
    I thought I read somewhere you can disconnect the the main board to test the backlight but I
    have not tried that because I was not sure if that was ok to do.
    Are there any steps you can suggest to narrow down the fault?
    Thank you in advance for your help.
    09-07-2024, 05:50 AM
  • C152Heavy
    Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
    by C152Heavy
    Summary for TL-DR readers:
    • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
    • Have obtained Samsung schematic & service documents - Can upload if helpful.
    • Have read ALL applicable threads
    • C1818 and CP820 replaced as low hanging fruit
    • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
    • VCC pin (18) of PFC...
    01-11-2023, 02:53 PM
  • sansanpartida
    Samsung QE82Q70RAT no backlight
    by sansanpartida
    Hi everyone!
    Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
    My issue: No backlight.
    Model: QE82Q70RAT
    Type No: QE82Q70RAT
    The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
    So hopefully, I can fix this cheaper.
    05-22-2024, 06:56 AM
  • howardc64
    Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
    by howardc64
    TV was fixed just after removing Samsung's rear snap cover.
    This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
    Maybe PSU->backlight connector didn't have a good contact?...
    07-23-2025, 12:34 AM
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
